Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: leaking oil around injectors what should I do
    Jul 2016
    Perth WA
    So what's the rationale behind the continued pumping of the primer after the engine has started? Is it to get rid of any ore possible air bubbles in the lines?
  2. The Following User Says Thank You to PRIGBY For This Useful Post:
    BigRAWesty (20th August 2016)
  3. #12
    Quote Originally Posted by PRIGBY View Post
    Spot in..
    You need to force it threw..
    The pump sucks fuel.. not air.
    So you gotta assist it.
    Quote Originally Posted by markstevo View Post
    Does anybody have the part number for the seals
    13276-2W211 for Direct Injection.
    Built into the pump is a circuit board, and this apparently gets hot so fuel flows under or over or near it, to keep it cool. If you get an air lock in the pump, just running the car wont remove it and then you over head the pcd and then its fried and then your up for a new pump. So I have been told and from my findings last year on this. So continually priming whilst the motor running will push any air locks out.
    jsawrey (12th July 2018)
  6. #14
    Jun 2021
    Hi,
    I got Nissan patrol 2010 3L Turbo Diesel Y61 Model. Suddenly there is an oil leak on top of 3rd injector.
    Can someone let me know what can be the reason. Only 160 000km so far.
    Please let me know how to fix this. I have attached a picture.
    Mark western A4b56fe1b-c40e-488c-a3b3-0d79c73df7b8.jpegustralia
  7. #15
    Jun 2021
    Hi,
