Page 15 of 21 FirstFirst ... 1314151617 ... LastLast
Results 141 to 150 of 208
Thread: Tow balls are not to be used as recovery points
  1. #141
    Quote Originally Posted by 4bye4 View Post
    You can't win can you? No matter how many time it's published there are still going to be people that do stupid things. You can by a recovery kit from all sorts of places between $50 and $100 or so with no instructions and very little in the way of warnings either. The other thing that bothers me is if enought people get hurt or killed, somone in a white shirt and tie in an office somewhere will just ban the use of snatch straps, or legislate the use of reflective shirt, protection for the chest, steel toe cap boots, helmet and eye protection before you are permuitted to attach a tow line of any sort.
    Maybe they don't put instructions on/in a recovery kit is for liability reasons.
    Maybe they should recommend a course before using any equipment
    But everyone's an expert out in the bush and that where the accidents happen.
    If it doesnt look safe chances are it isn't, refuse the recovery and think it out
    with a bit of brainstorming,
  2. #142
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    I agree TD but I have to admit when I first started driving 4WD, I probably would have thought a bull/roo bar was OK to snatch/tow on, untill someone told me. Probably not a tow ball but I might has done it if I didn't know. IMO a warning similar to that at the top of the forum page should be mandatory on all recovery kits, either on or in the box when purchased or on the strap.
  3. #143
    Since 2010 all Snatch Straps must be packaged with almost all of the suggestions mentioned so far... https://www.accc.gov.au/system/files...er%20guide.pdf
    3 Accompanying information
    (1) A motor vehicle recovery strap must also be accompanied by
    a document, other than the packaging, stating the following
    information written in English—
    (a) a recommendation that the minimum breaking strength
    of the strap should be between 2 and 3 times the
    vehicle’s gross vehicle mass (GVM);
    (b) advice that the strap must be suited to the GVM of the
    lighter of the 2 vehicles used in the recovery process;
    (c) how to use and maintain the strap.
    (2) Without limiting subsection (1)(c)—
    (a) the information to accompany a motor vehicle recovery
    strap must state all of the following—
    (i) persons intending to use the strap should consider
    completing a nationally recognised four wheel
    drive training course or contact a four wheel drive
    club for comprehensive advice on the proper
    selection and use of the strap;
    (ii) the strap must not be used for lifting or
    conventional towing;
    (iii) persons intending to use the strap must ensure that
    the strap is not damaged and is in usable condition;
    (iv) the strap’s strength and stretch are reduced when
    the strap is saturated;
    (v) something like a recovery damper, heavy bag or
    blanket must be draped over the strap during its use
    to reduce any unintentional rebound of the strap;
    (vi) while the strap is being used, persons situated
    outside the motor vehicles involved in the recovery
    process must—
    (A) be kept at a safe distance (recommended as
    at least 1.5 times the length of the
    unstretched strap) from either of the vehicles
    involved in the recovery process; and
    (B) never situate themselves within the path of
    the vehicle performing the recovery; and
    (b) the information must also include the following—
    ‘WARNING—Always follow product instructions. It is
    important to correctly attach the motor vehicle recovery
    strap to a motor vehicle. A standard tow ball or vehicle
    tie-down point is not designed for this purpose and may
    result in the strap or a vehicle component detaching
    from a motor vehicle and striking and seriously injuring
    or killing a person. Only attach the strap to a vehicle
    recovery point or device that is suitably rated for use
    with the strap. Incorrect use has previously resulted in
    serious injury and death.’.
  4. The Following 2 Users Say Thank You to the evil twin For This Useful Post:
    Chubba (23rd August 2016), mudski (16th August 2016)
  5. #144
    477 Post(s)
    Thanks ET. TBH I don't think I've ever seen any of this info sold with any strap I have seen. Apart from breaking strain and the like. I will have a closer look on Sunday at the 4wd show.
    I think the link that E.T has posted should be add to the OP.
    the evil twin (16th August 2016)
  7. #145
    Thanks ET. TBH I don't think I've ever seen any of this info sold with any strap I have seen. I will have a closer look on Sunday at the 4wd show.
    Hiya Cobber,
    An ARB one that I was presented with after some Lectures and Training I did about 3 years ago is still in its box and has all the required warnings and product info and is also with the ones I get from from the Industry Vendor (who make them up to 400 tons rating... awesome bit of kit but you need a Forklift to rig it).
    If anyone is flogging them without the Mandatory Warnings they are taking a HUGE business risk so if you spot any I'd give 'em a polite heads up.
    I would almost bet you can find a few :-)
  8. The Following User Says Thank You to the evil twin For This Useful Post:
  9. #146
    Aug 2014
    Kingsley WA
    15 Post(s)
    Hey @ET my apologies, I just checked the "recovery kit from Supercrap" given to me last Christmas and it does have the warnings you quote on a piece of paper at the bottom of the bag. I didn't know it was there and not very obvious but it does comply with the law.
  10. The Following 2 Users Say Thank You to 4bye4 For This Useful Post:
    the evil twin (16th August 2016), threedogs (17th August 2016)
  11. #147
    477 Post(s)
    Yeha will be having a closer look. I cannot recall ever seeing this, but like 4bye, its not real obvious to see i suppose.
  12. #148
    No apols needed, Cobber... and totally agree that the A.S. Packaging Standard could maybe insist on something a bit more prominent.
    Packaging is the first thing in the bin hence the requirement for the seperate pamphlet/instructions which, we all know as good aussie blokes, is usually in the bin about 2 micro seconds behind the packaging
  13. #149
    You need to do a course to work as a dogman or rigger.
    Yet any jo blow can use a snatch strap , winch or drag chain
    with no accreditation, hooking two 4 ton 4x4 together.
    just saying
  14. #150
    just saying
    True dat... but maybe not a totally fair comparison.
    Yes, you need a ticket to work as a Dogman or a Rigger in Industry but equally Jo Blow will also need a ticket to operate a 4X4 and another one again to recover a 4X4 in many but certainly not all Industry or Statutory employment here in WA.
  15. The Following 2 Users Say Thank You to the evil twin For This Useful Post:
    growler2058 (17th August 2016), threedogs (17th August 2016)
