Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: Plastic Jerrys on the Roof?
    May 2016
    lower west victoria
    30 Post(s)
    I'm wondering if anyone has any experience carrying those 20litre plastic jerrys on their roof rack. I'm wondering when laid on the side, do they leak out the breather. I have 6 of the Sceptor ones made in Canada which are very good quality plastic ones.
    Or any other way I could carry 2 20L jerrys outside the vehicle.
    Thanks for any help.
    Patrol Freak liftlid's Avatar
    Nov 2010
    6 Post(s)
    Fill em with water and give it a try
  3. The Following User Says Thank You to liftlid For This Useful Post:
    10G (15th August 2016)
    I've ran them once and they didn't leak, but they do balloon out just need to release pressure.
    Sent from my XT1068 using Tapatalk
    Perth WA
    63 Post(s)
    You can purchase holders from ARB that bolt onto roof racks
    May 2016
    lower west victoria
    30 Post(s)
    Quote Originally Posted by liftlid View Post
    Hey that's a good idea, good old common sense.
    Thanks.
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    Don't be like a lot of numbtees we come across and carry full cans all around Oz. Fill them at the last place you can possibly get fuel and then pour them into your tanks as soon as possible (like stopping for morning tea). Always plan to carry EMPTY cans whenever possible.
  8. The Following 2 Users Say Thank You to BillsGU For This Useful Post:
    threedogs (16th August 2016), Woof (16th August 2016)
    Patrol Guru Sprock's Avatar
    Jun 2015
    Heyfield Vic
    35 Post(s)
    ☝🏼️more common sense advice that is often not thought of by a lot of people , saves carrying full jerrycans unnecessarily, avoids heat expansion / pressure , leaking & making a mess & then losing the fuel which defeats the purpose of carrying the 'extra' fuel . Tip it into the main tank as soon as it will fit 👍🏼
  10. #8
    you won't really get the same heat expansion as fuel though i would not have thought.
    I have carried plastic fuel jerry not eh roof quite a few times. I make a point of tightening the caps with Multigrips before they go on the roof. make sure you have those multi grips to undo when you need to. as noted empty as soon as you can.
  11. #9
    Protect them from rubbing on each other using carpet or rubber conveyor belt [thin]
  12. #10
    Advanced caveman21's Avatar
    May 2016
    sandgroper
    This is the key on rutted tracks good vibration protection and every stop give them a check that lids are tight , I ran 2 jerrys on a roofrack bracket and had a large syphon hose long enough to reach the tank without removal of jerrys and had 2 straps on each can .Done 8500km through the kimberlys for 3months no spillages
    Why do caveman drag there woman by there hair ?
    Cause if you drag them by there feet they fill up with dirt
