Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: hidden Winch install
    Expert rusty00's Avatar
    Jun 2015
    South Eastern VIC
    Quote Originally Posted by altech View Post
    Hi Rus, Sorry not from Ebay , i just did Google search and I think I use this supplier - http://www.nissangupatrol.com/produc...alloy-bullbar/
    Or there are some ebay ones too http://www.ebay.com.au/itm/GU-Patrol...kAAOSwx-9WubR6
    http://www.ebay.com.au/itm/GU-Patrol...4AAOSwECZUrGM5
    http://www.ebay.com.au/itm/GU-Patrol...7YP6UTievn59lQ
    pretty sure there are the same Guy , hope this helps cheers Alex
    That's awesome thanks.
    Will make contact with them and do the same install as you have.
    Not sure what difference the 2012 is over your model. Will soon see.
    Have you used your yet and if so how did everything go.
    I assume it makes no difference not having a bar and just the winch?
    2012 GU8
  2. #12
    Expert altech's Avatar
    Nov 2011
    Rupanyup, 3388, VIC
    Quote Originally Posted by rusty00 View Post
    Hi Rus , No haven't use it as yet , the Bar is there for Non bull bar fitting , So if have a fitted bull bar that has winch candle built in. and just a Note : if you read on the winch Bar web site , right at the end of bar info , there's a line that mentions about not being Airbag compatible. cheers Alex
