Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: About to do the axle seals, swivel hubs and bearings. HELP!!!!!!
    Apr 2011
    Vic, NT, Tas - On the move with work
    I have just got the kit for my GQ to do the complete axle seal to wheel bearings including king pins and all the seals. I have read the Pictorial post by Tony which has been a great help and i will be using it while doing the job. I do however have a couple of things on my mind id like to know before i start.
    Just to give you an idea, i have never done this before so as much help as you can give would be great. Dont be afraid to treat me as a beginner because thats what i am with this job.
    I have all the parts needed i believe. I also bought a hub nut socket. What other tools do you reckon i need on hand for the job?
    I know how to pack wheel bearings with grease and i guess its the same for the other bearings in the kit? How much grease and how do i pack the CV joint?
    How do i set the pre load on the king pin or swivel hub bearings?
    How do i set the pre load on the wheel bearings?
    I realize you dont get the kingpin bearing cups with the kit. Whats the best way to get them out with out damaging the cups?
    I hope im not going to make a disaster of this task. Im setting the whole easter weekend aside to get it done so i hope its drivable next week. haha.
    Any advise would be great, especially if you have done this before.
    Thanks in advance and a happy and safe easter to you all.
    Carl
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Just follow Tony's post mate and give us updates as you go ... a lot are away over Easter but we will be popping in to check if you need a hand!!
    Good luck with it and I'm sure you'll be fine mate.
    Patrol God Finly Owner's Avatar
    Jul 2010
    Waterford West Qld
    Quote Originally Posted by Burden View Post
    Carl
    Circlip pliers, small flat blade screwdriver, Bearing grease, rags, cleaning solution, and allen key socket type to fit cap bolts on hub, ratchet to fit socket
    Tim
    Apr 2011
    south east queensland
    there should be workshop manual around here some where, take alook at that
    RIP - valued member and true gentleman of this forum that will be missed by many! Silver's Avatar
    Feb 2011
    Brisvegas
    HTB grease for wheel bearings, moly grease for CVs, but check this, and not really sure what was meant to go into king pin bearings - read three manuals and still a bit uncertain. Used moly grease - LMM, but probably should have gone back on level on the Moly.
    swivel hub bearing caps are thin sheet metal with a lip seal around the circumfrence. If you clean where they live, you will see the swivel has a couple of recesses machined in. With care and a tool that fits into those recesses it is possible to knock the swivel hub bearing cups out without damaging the caps. Otherwise $30 each from Nissan.
    You might want to look for GU wheel bearing lock nut arrangement - it is a bit more civilised than the GQ. From my experience of a non genuine kit, the tab on the lock washer for the GQ wheel bearings aint to happy about the outer wheel bearing lock nut being torqued up to the specification in the manual, and I can't quite see the point of torquing to that setting. I get torquing the inner nut up and then backing it off, to make sure that all the bearing cups are seated properly.
    The two issues I had were (1)getting the axle back into the diff (not the diff housing). Eventually I got a bit cranky and just wiggled it about and said rude words, and blow me down, in it went.
    the second issue for me, which was easier than (1) was putting the circlip back onto the axle (the one that goes under the free wheeling hub). You may need to lever the axle out a bit to even see the circlip groove, but if everything is back in the right order, including the wheel bearing cups being set up against their stops, then all you are fighting is grease etc, and it will happen. Probably pretty easily, but don't bet on it :-)
    Take care of the seal in the end of the diff housing when installing the axle and cv. If you google packing CV you'll find a couple of sites that help. All I did was put the wheel end of the axle into a vice, and squished the grease in with something very similar to a ruler on the side closest to me, while rotating the long end of the axle, until it squished out the other side of the CV.
    If you are going to all that trouble, and there is anything dodgy about your brake rotors, consider replacing them now.
    Swivel hub bearing pre load. I think the (dodgy) consensus is, if it worked with the shims and the old bearings, it will probably work with the new ones.
    Finally, play very close attention to the scraper seal, backing seal (or whatever it is called) and associated metal work as you take it off, to make sure it goes back on in the right order, and make sure you put the new ones on before installing the swivel hub :-)
    Keep track of what is happening as you undo the lock nut and then the bolt that sets the steering lock on each side - it is also one of the bolts that keeps the wiper seal in place. If you wind the bolt too far back in, you can allow the steering lock to increase to the point where you damage the CV.
    If you clean the CV (I used kero and a brush, then kero in a kero gun with the compressor, and then water to wash the kero out, and then air to remove the water) and it feels clunky and yucky, that possibly only reflects that the CV is now dry. If it binds and carries on while lubed, or there are chip in the outside of the CV cup - you'll know when you see them, maybe get more advice. Pensioner mate over the road had rust and major clunks, and chips in the left hand side CV, and just chips in the RHS. Advice from mechanic was only LHS needed replacing. Make sure you get the right CVs, GU are bigger than GQ.
  6. The Following User Says Thank You to Silver For This Useful Post:
    Irvs (23rd April 2013)
    Feb 2011
    Shed
    45 Post(s)
    Hard to describe how to pack a wheel bearing but here goes.
    Easiest way i found was palm full of grease (you may want rubber gloves) and massage the grease into the rollers. Push and work the bearing around in the grease so that it gets right in take your time and ensure the grease gets right through the entire bearing i dont believe there is such a thing as over greasing if you get my drift
    Take your time take photos for reference and definately use Tonys post made my life easier.
    Good luck with it you'll be right just be systematic
  8. #7
    Oct 2010
    Quote Originally Posted by growlers71gq View Post
    DON'T over grease!!!! (nice one growler!!! lol).
    Everything said is perfect - you basically "cut" down on the blob of grease in your palm to fill the gaps in between the rollers on the inside of the inner and outer housing of each bearing - the seals, the outer case of the bearings and the inside of the hub only need a nice light application (about 1-2mm thick all round just to lube them). It's more important that the inside of the bearings are full. Too much grease will end up blowing through the seals ...
    Good luck with it ..
  9. #8
    Feb 2011
    Brisvegas
    Sad to say I quite like packing wheel bearings. must relate back to child hood mud pies :-)
  10. #9
    Apr 2011
    I have been on this job today and all is apart and fine other than removing the axle oil seal. I removed the swivel housing races and cap no problem. How do you remove the oil seal? I wanto get it all back together tonight with new bearings so if any body is on the forum at the moment and have done this before id love your advise. thanks.
    Hope your weekends are going good guys.
  11. #10
    Feb 2011
    Shed
    45 Post(s)
    Mate i got a pair of pointy nose pliers and ripped the bugger out then to get the new one in used a socket the same size as a drift and gently tapped them in
