Results 1 to 10 of 20
Thread: New gps coordinates for Australia?
    http://www.sciencealert.com/australi...s-to-the-north
    Due to tectonic shifts, the entire continent of Australia has moved 1.5 metres north over the past 22 years, putting it out of sync with global positioning systems (GPS).
    To fix the problem, the government's announced that the country's latitude and longitude will officially be updated to reflect the continent's new position.
    But for Australia, those coordinates were last updated by the national body - the Geocentric Datum of Australia (GDA) - in 1994, and since then, the continent's moved more 1.5 metres.
  2. The Following User Says Thank You to AB For This Useful Post:
    NissanGQ4.2 (2nd August 2016)
    This is important because GPS works out your location by calculating where you aren't.
    Once it has where you aren't sorted out you must be where you are.
    If, due to errors where you aren't now becomes where you are then the GPS system is no longer accurate.
    Given that the new datum is calculated for 2020 then you won't be where you think you are for another 3 and 1/2 years
  4. The Following 11 Users Say Thank You to the evil twin For This Useful Post:
    AB (2nd August 2016), Bigcol (5th August 2016), BigRAWesty (4th August 2016), firm351 (3rd August 2016), gaddy (2nd August 2016), jack (3rd August 2016), mudnut (2nd August 2016), NissanGQ4.2 (2nd August 2016), Sherro (3rd August 2016), Stropp (4th August 2016), Woof (4th August 2016)
    This is important because GPS works out your location by calculating where you aren't. Once it has where you aren't sorted out you must be where you are. If, due to errors where you aren't now becomes where you are then the GPS system is no longer accurate. Given that the new datum is calculated for 2020 then you won't be where you think you are for another 3 and 1/2 years
    But where you've been hasn't really been where you've been so where you thought you were was in fact where you might want to be but haven't been there yet, or have you?
  6. The Following 3 Users Say Thank You to AB For This Useful Post:
    Touses (3rd August 2016), Toy-Eta (4th August 2016), Woof (4th August 2016)
  7. #4
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    No wonder I can't catch any pokemons
    >>>tappin from tassie
    Hello from Under Down Under!
  8. The Following 6 Users Say Thank You to taslucas For This Useful Post:
    Avo (4th August 2016), BigRAWesty (4th August 2016), Maxhead (3rd August 2016), mudnut (2nd August 2016), Touses (3rd August 2016), Woof (4th August 2016)
  9. #5
    84 Post(s)
    1.5 metres north. that is a lot of acreage moving from the Southern Mid latitude Air Circulation cell to the dry area between it and Southern Hadley Air Circulation Cell.
    Boom! there is our climate change solved right there, unless of course the grid lines aren't there yet?
  10. #6
    Does this mean that Victoria is going to get a little bit warmer?
  11. #7
    Aug 2014
    Perth
    10 Post(s)
    What drugs are you on?
  12. #8
    May 2016
    lower west victoria
    30 Post(s)
    I heard this morning that Australia is moving 7cms north and 11cms west per year.
    Still doesn't get me any closer to Cape York.
  13. The Following 2 Users Say Thank You to 10G For This Useful Post:
    Avo (4th August 2016), Touses (4th August 2016)
  14. #9
    Tasmania might get a summer yet!!!
    You sure?... what's that creeping up behind you then?
  16. The Following User Says Thank You to the evil twin For This Useful Post:
