Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 45
Thread: Pushing on with TB42E turbo upgrade
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Was big rigs engineered?
    >>>tappin from tassie
    Hello from Under Down Under!
  2. #12
    Patrol Guru Irish's Avatar
    No idea mate.
  3. #13
    Aug 2011
    North West Tas
    56 Post(s)
    Sorry, I was asking Darren. I thought he might know
    >>>tappin from tassie
  4. The Following User Says Thank You to taslucas For This Useful Post:
    Irish (29th July 2016)
  5. #14
    22 Post(s)
    >>>tappin from tassie
    99.9% certain it was.
    96 GQ coil/Cab
    08 G6eT
  6. The Following 2 Users Say Thank You to Ben-e-boy For This Useful Post:
    Irish (30th July 2016), taslucas (29th July 2016)
  7. #15
    Okay, update.
    So this morning I picked up the turbo, intercooler, lines and the bloke even threw in a couple of pro Comp gauges and a pod filter because I'd driven so far.
    We are officially on our way.
  8. The Following User Says Thank You to Irish For This Useful Post:
    NissanGQ4.2 (31st July 2016)
  9. #16
    22 Post(s)
    Is there much shaft play? There will be a bit Side to side for oil clearance. front to back is not so good. Also for piece of mind, remove the turbing housing and check for cracks......................might aswell port it while it off too ;p.
    96 GQ coil/Cab
    08 G6eT
  10. #17
    Yeah about 1mm side to side, just the tiniest perceptable movement front to back.
    If need be theres a place I can get a rebuild and rebalance for under $400.
  11. #18
    22 Post(s)
    Quote Originally Posted by Irish View Post
    That alright, I wouldn't be worried about that
    96 GQ coil/Cab
    08 G6eT
  12. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    Irish (31st July 2016)
  13. #19
    Spoke with an engineer the other day, looks like I'll be needing to get an emissions test done. Theres only one place in VIC that does it and of course they charge $700 for the privilege.
    Once it passes, the engineer will give the car a once over and then hopefully sign it all off.
  14. #20
    Okay, quick update:
    Took the old girl for a final spin yesterday before the conversion, got home and started ripping stuff out of the engine bay so I could test fit the manifold and turbo to get an idea of space etc.
    Here's what it looks like now:
  15. The Following User Says Thank You to Irish For This Useful Post:
    taslucas (19th September 2016)
