Results 1 to 8 of 8
Thread: Silicone hose Cooling system : any good ??
    Advanced LandRoverGhost's Avatar
    Jun 2016
    Warrumbungle
    Question Silicone hose Cooling system : any good ??
    Hi , some of the rubber hoses in my 'new' Patrol , of the cooling system need replacement.
    Are Silicone hoses any good ?
    Thanks: J.
    333 Post(s)
    They are gone mate. Keep your old hoes if they have any life in them as spares. I carry old hoses stashed in the rear quarter panel behind the trim. Fan belt and air on belt goes in there too!
  3. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    LandRoverGhost (14th July 2016)
    X 2 swap them over to silicon and use to old as spares.
    Aug 2016
    QLD
    Who would be a good supplier or manufacturer of the silicone hoses, I've heard nasty things about some of them. Having those spares can really save your bacon. Also some tubes of epoxy helps to fix cruisers with cracked radiators.
    475 Post(s)
    Personally I'd use branded rubber over the cheap silicone hose sold these days. Besides you can't just use your old worm drive hose clamps on silicone, it will chew through the silicone the first time you tighten them up. You need to buy lined clamps so theres no perforation in the clamp to rip the hose. Gates brand hoses are my pick.
  7. The Following 2 Users Say Thank You to mudski For This Useful Post:
    LandRoverGhost (10th August 2016), mudnut (10th August 2016)
    Here you go, unsure of your motor
    http://www.ebay.com.au/itm/Silicone-...UAAOSwwo1XfgR1.
  9. #7
    Jun 2016
    Warrumbungle
    That is very useful news ! Rubber will stay :-)
  10. #8
    Aug 2016
    QLD
    Speaking of hoses and Gates. I just found this http://www.gates.com/catalogs-and-re...e-coolant-hose . Meant to be getting an early night so I can do a coolant flush and transmission flush but I can't help but researching. Now I'm wondering if I too should have been replacing my hoses but they look pretty good at the moment.
