Results 1 to 10 of 12
Thread: MAX TRAXs REPAIR STUDS
    http://www.ebay.com.au/itm/Maxtrax-R...-/191895174879
    Spied these stud repair kits for Max Traxs and similar, might come in handy up to a point
  2. The Following 2 Users Say Thank You to threedogs For This Useful Post:
    04OFF (12th July 2016), Stropp (15th July 2016)
    Hardcore 04OFF's Avatar
    Brisbane,QLD
    12 Post(s)
    That's actually pretty cool 3D, i gave my max trax away because i only ever used them on other peoples stuck cars, and most people just don't get the whole "dont spin your wheels" thing, and so just wreck the teeth on the max trax.
    Now i pull people out with the winch, so now i just have to stop them running over the winch rope (lol)
    Expert Mike02Ti's Avatar
    Jun 2016
    Rockingham WA
    4 Post(s)
    I seen these too. My only concern was will they snap out and become a projectile if a wheel does spin on them.
    2002 GUIII Ti 4.8
    Details here
    Ballarat, Vic
    178 Post(s)
    Quote Originally Posted by Mike02Ti View Post
    Perhaps, but as an alternative to buying new Maxtrax they look like they would be worth a try. However their cost is no easier to swallow than the price of Maxtrax. Both seem grossly over-priced to me for what they are.
  6. The Following User Says Thank You to Cuppa For This Useful Post:
    BigRAWesty (13th July 2016)
    Maybe they should of made a mould and pressed out some kind of plastic ones,
    just to make it a bit more cost effective.
    @Cuppa do you think he [seller] had these made especially to suit the Max Trax or
    do you think he saw a product used else where and thought Hey that will replace burnt teeth
    on the Traxs
    Gives me an idea much cheaper than that.
    Do they only burn the end ones or the lot if mistreated
  9. #7
    Ballarat, Vic
    178 Post(s)
    I can’t imagine any other use for them.
    It may be that production cost ‘justifies’ the price, but only viable because of the unreasonably high replacement cost of more Maxtrax plastic
  10. #8
    Jun 2016
    Rockingham WA
    4 Post(s)
    @threedogs any of them can burn due to wheel spin no matter where they are on the board. In saying that the ramp ends and the first couple after them on top of the board are usually the ones to go first.
    2002 GUIII Ti 4.8
    Details here
  11. #9
    477 Post(s)
    A packet of 6mm stainless bolts with a nut and two washers about 10mm or so long would surely do the trick wouldn't it?
  12. The Following User Says Thank You to mudski For This Useful Post:
  13. #10
    Ballarat, Vic
    178 Post(s)
    I think I’d most certainly give that a try before shelling out $5+ per stud.
  14. The Following User Says Thank You to Cuppa For This Useful Post:
