Results 11 to 20 of 21
Thread: I'm stranded - 4.8 blew a radiator apart and then hole in replacement
    Crack the radiator cap so it can't build any pressure on the rest of the drive.
    SpecialDave (12th July 2016)
  3. #12
    Expert SpecialDave's Avatar
    Apr 2015
    Greensborough / sunshine / Aspendale. Kind of homeless at the mo
    Thanks legends and you are - all legends!!
    I made it just - freeway was fine but as soon as slow to corner etc up she went. I ended up running a couple of mostly ambers but i did have my orange flashing light on the roof going and there was no traffic at all so I feel like it was on the border of ok.
    I didn't let it cook on the way home but there's a suspicious oil smell that requires investigation - think I maybe looking at mechanic as I don't have the time to do a diy this time.
    Selling a house that I pay for but am not allowed to live in and going through divorce with a little fella to consider (whom I see as regularly as is possible and ultimately will be 50:50) and a job that is driving me bonkers but I've been there 5 1/2 years so 18 months and long service if I can manage to hang on! It's all a fair whack!
    Any newbies reading this take note, being a top bloke (or person to be non gender specific) is a simple as contributing and sharing and helping out when, where and how you can, it eventually comes back. when needed it most like tonight the lads came through for me and I was at the end of my emotional and mental capacity to take life's shit too... The lesson I learnt through all the crap is put my damn pride aside and ask for help if I need it. There's no shame in asking for help - the shame would be to not be greatful and reciprocate when you get the chance.
    Thanks again I owe you all a beer or 6!
  4. The Following 15 Users Say Thank You to SpecialDave For This Useful Post:
    AB (12th July 2016), BigRAWesty (12th July 2016), Cuppa (12th July 2016), Hodge (12th July 2016), jack (12th July 2016), macca (12th July 2016), mudnut (12th July 2016), MudRunnerTD (12th July 2016), mudski (12th July 2016), Rossco (12th July 2016), Sir Roofy (12th July 2016), threedogs (12th July 2016), Touses (12th July 2016), Winnie (12th July 2016), Woof (12th July 2016)
  5. #13
    Save yourself a few dollars and start with the simple ones first. Throw the thermostat in a pot of boiling water and put it in a bowl of cold water do it a couple of times and see it open and close, if that works ok fill up radiator with some water and put a new radiator cap on. If it still no good yes, you have some problems.
    Sent from my XT1068 using Tapatalk
  6. #14
    Oct 2010
    Old Bar, NSW
    Quote Originally Posted by SpecialDave View Post
    Don't like the sound of that, could be something else certainly hope it is for your sake.
    Macca
  7. #15
    Apr 2015
    I chucked it into a pot of cold water and slowly brought it to boil the thermo wasn't touching the pot, it was suspended and completely submerged - it no do nuffing!
    I think it's cactus - I'll replace with a genuine anyone know of a place either port Melbourne or sunshine or in between the 2 that would stock?
    02 GU3 Dual Fl Y61 4.8 Auto. 3"OME, Snorkel, roof tray, Dual Batt, CB, d8r winch, ledlightco bar, fact steel BB, Elec Tow. hid spots, rvrs & tow cams, rear door rattle fix, saas dual volt gauge, mostly fin cust dash pod, ludicrous work lights. TO DO: convert headlights - led? rear tails, full overhaul trannie & engine. rear storage. door table. O/h interior storage, Paint Matt black. Bash guards. Side rails. Roof ladder. Awning.
  8. #16
    The only one that I know that has genuine would be Mr Nissan or maybe @mudski.
  9. The Following User Says Thank You to jay see For This Useful Post:
  10. #17
    Sep 2013
    Edgewater, WA
    It doesn't look good from what you have discribed. If your smelling oil in the radiator and it was running hot on a cold evening with the thermostat removed, then I would say you have a blown cylinder head gasket or a cracked head. Probably caused from the faulty thermostat you tested. If your going to change the gasket yourself, have the head checked by an automotive machine shop to make sure there is no damage.
  11. The Following User Says Thank You to Nichw91 For This Useful Post:
  12. #18
    Apr 2015
    The oil smell wasn't from rad, not even from head more either old spill or old leak towards the trannie and I thoroughly checked there's no water in the oil so head gasket seems sound - when I was doing freeway driving it stayed at temp no prob it was stop start that sent the needle north and a head gasket etc would have boiled regardless of speed and airflow so I'm hopeful a thermostat replacement will fix it..
    I hope
  13. The Following User Says Thank You to SpecialDave For This Useful Post:
  14. #19
    Good luck mate, certainly sounds like the Thermostat is knackered. any Bursons or Repco should sell an after market job if you want to save some cash. There is a Repco in Sunshine on the corner of Andersons Rd near the Cop Shop. Good luck mate.
  15. #20
    sunshinecoast
    just a thought . might pay to check the radiator fan is working properly .
