Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: I'm stranded - 4.8 blew a radiator apart and then hole in replacement
    Expert SpecialDave's Avatar
    Apr 2015
    Greensborough / sunshine / Aspendale. Kind of homeless at the mo
    My pressure is way up and split the top open on my radiator so I managed to get a replacement from wreckers and it either had or developed a small hole - what would cause my system to have increased pressure - I'm sitting in a car park on a night that may have snow - I have heaps of tools etc.
    Heater core? Any suggestions as I'm lowcash and need to get her going at least to limp home
    02 GU3 Dual Fl Y61 4.8 Auto. 3"OME, Snorkel, roof tray, Dual Batt, CB, d8r winch, ledlightco bar, fact steel BB, Elec Tow. hid spots, rvrs & tow cams, rear door rattle fix, saas dual volt gauge, mostly fin cust dash pod, ludicrous work lights. TO DO: convert headlights - led? rear tails, full overhaul trannie & engine. rear storage. door table. O/h interior storage, Paint Matt black. Bash guards. Side rails. Roof ladder. Awning.
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    thermostat jammed shut hope someone is close by to help you out
  3. The Following User Says Thank You to Sir Roofy For This Useful Post:
    SpecialDave (12th July 2016)
    Apr 2015
    How does one Unjam thermostat?
    TRAFALGAR VIC
    35 Post(s)
    Quote Originally Posted by SpecialDave View Post
    if you think that's the problem just take it out and get yourself home
    keeping an eye on temps you should be ok
  6. The Following User Says Thank You to Sir Roofy For This Useful Post:
    Oct 2010
    Old Bar, NSW
    13 Post(s)
    Pressure is due to cap not working or leak from a cylinder pressurising the system.
    Take the cap off and check for air bubbling out of the radiator. If not too bad you could possible drive it.
    Macca
  8. The Following User Says Thank You to macca For This Useful Post:
  9. #6
    476 Post(s)
    where are you?
    I'd try just removing the thermostat just to get home. Hopefully this might help.
  10. The Following User Says Thank You to mudski For This Useful Post:
  11. #7
    Apr 2015
    Therms removed now in motion - fingers crossed
  12. #8
    334 Post(s)
    Good luck bud, hope you don't have far to go. I assume your not in the RACV?
  13. The Following User Says Thank You to MudRunnerTD For This Useful Post:
  14. #9
    Apr 2015
    Nope and couldn't afford to keep roadside (going through very ordinary divorce) so it's gotten very hot and I'm pulled over letting her cool - only another 20kms to go
  15. #10
    334 Post(s)
    Bugger mate, sorry dude, that would be shit. Have you got plenty of water? Where are you? If I was close I'd come get you mate but I'm in Geelong mate.
  16. The Following User Says Thank You to MudRunnerTD For This Useful Post:
