Results 11 to 20 of 22
Thread: Water gets in when it rains??
    176 Post(s)
    If you find a source (or part no.) for new scrivets let us know. When I had the same problem I ended up daubing a bit of windscreen mastic over each scrivet. A bit messy, but several years down the track it’s still keeping out the water, but it would be good to have a full set of scrivets for when the windscreen inevitably needs replacing.
  2. #12
    May 2016
    hey guys if you go to nissan
    i priced a set of scrivets $24.35 from nissan
    to hold the scuttle pannel in
  3. The Following 2 Users Say Thank You to mattyk For This Useful Post:
    Bloggsy (11th July 2016), Cuppa (13th July 2016)
  4. #13
    476 Post(s)
    Quote Originally Posted by mattyk View Post
    Theres a small plastic plug you should also replace if your replacing those scrivets.
    You need 7 scrivets and 4 of those plugs. And i bet you will break the small plastic scew at either end of the panel too. So should get those too just incase....
  5. #14
    176 Post(s)
    You wouldn’t have a parts diagram with part no’s would you @mudski ?
  6. #15
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Has anyone got pics of doing the job?
    Mine leaks bad and I reckon this thread has just taught me why
    >>>tappin from tassie
    Hello from Under Down Under!
  7. #16
    476 Post(s)
    mmmmmmmaybe
    I'll have to look up your model just incase they are different to the early shape GU's.
  8. #17
    476 Post(s)
    Hopefully you can see the part numbers. They are the same throughout the GU series @Cuppa
    Cuppa (14th July 2016)
  10. #18
    476 Post(s)
    >>>tappin from tassie
    @taslucas
    This may be of help?
  11. The Following 3 Users Say Thank You to mudski For This Useful Post:
    Cuppa (14th July 2016), mattyk (16th July 2016), taslucas (13th July 2016)
  12. #19
    176 Post(s)
    Thanks Mark. Much appreciated.
    I have copied them & stored away on my computer for future reference.
  13. #20
    Expert Daveyboyjunior's Avatar
    Feb 2015
    Dartmoor, England
    I'm getting water in on passenger to. It's coming through one end of the grab handle on the ceiling over the door.
    From what's been said I'll investigate the sunroof side of things!
