Hi all, thought I would start a thread about my car and what will be done to it over time. This will be an evolving thread as things happen.
History:
I bought the TI spec model with the 4.8 having Dual Fuel. Previous owner actually fitted an oversized sub tank too! Bonus.
It was close to Bone Stock when purchased apart from a brake controller and a stuffed Anderson plug on the rear end, a GME UHF that has wires and tape all over the place and a crappy hands free kit.
Im the 3rd owner and got a pretty good service history with it. It was well looked after. Hardly seen any off road work apart from a few small tracks up North. Some scratches etc around but to be expected and not overly fussed about.
It has been a bit neglected inside, not any real damage, just unclean.
Now just Tidying it up to suit my needs
First week in having it ALL interior come out for cleaning and running cables apart from front carpet. I was surprised at how clean everything was under the trim panels. No signs of dust anywhere. Rear carpet was filthy so that got totally removed and cleaned. The underlay was stuffed so got thrown in the bin. It has now been replaced by foam anti fatigue matting which has worked extremely well.
All leather seats have been totally scrubbed and then gone over with leather protector.
Trim panels have been removed, hosed off/ scrubbed and now recleaned once gone back into the car.
The bloke who had it before me obviously had no concept of wiring. I have pulled out the busted UHF which was wired straight to the battery (not been replaced yet), hands free kit which was knotted around half the wires under the dash, an unused video cable running to the rear and a stuffed anderson plug running to the rear. The wiring is whats taken me about a week to complete
The Patrol didnt come with a remote central locking button. Further investigation showed I had it all there, so im guessing the remote got lost or didnt work, hence why I never got it when purchased.
So off to Jaycar and bought an alarm kit. The alarm side was dead simple to wire up. The central locking was a nightmare. I spliced into the white central locking controller via the 2 thick blue wires. That didnt work. Located the green relay. Got 3 doors and the tailgate to fire but not drivers side. Took out the drivers side actuator motor and deemed it to be stuffed after I cut it open. I could get it to move but there was no torque from the motor to actually operate the actuator on the door lock (under load)
So that is now residing in the wheelie bin and replaced with an off the shelf actuator from Jaycar using 3 of the 4 original wires in the door.. I spliced into the wires on the green relay box from the alarm and now everything is working fine!
Now I have played around with this alarm a bit , I really like it. The alarm has been set on door, accessory power, impact sensor and tamper (standard) protection. NATS takes care of the rest of the immobilisation.
The alarm talks to you as standard saying "armed" or "disarmed". I thought this would become really annoying but I actually like the cues it gives me, like if the kids dont close the door properly on arming it says "please close the door" within 5 seconds of me pressing the lock button. The tamper side of things say "dont touch me" with a few siren chirps as a warning . Found this out mucking around with fuses for the door lock trigger.
If the alarm was triggered by the door being opened or accessory power was applied while im gone, the alarm tells me "the door was opened" once I disarm and enter the car. As it sits now, the voice stays. Time will tell if I get sick of it.
Valet mode I found very handy so far. What this does is disable the alarm side until you reactivate it, instead of having the alarm auto arm itself after a certain period of time. Great for having the doors open for a while down the beach fishing or working on the car.
Auto arm does not lock the car if the doors have been opened. This means there is no chance of the alarm rearming itself and locking the keys and the keyfob in the car. Auto rearm will only relock the doors IF the doors have not been opened.
It has support for auto windows up and a remote boot trigger too. I highly recommend this alarm system
The wires I have now run through the car go into a 10 way fuse box rated to 100 amp that is powered once the accessories are turned on by the key. Anything that will be power hungry has its own switched relay powered from the fuse box and only the trigger wire for that relay comes from the fuse box (eg front light bar)
This has given me plenty of room to grow the system if need be.
Whats been added.
LED 120w 22" Light bar up front
LED 27w spotlight rear
4 x USB Ports in rear of center console replacing the ash tray on the back.
2x 12v power outlets rear cargo area
Eonon GA2114 Android Head unit 7" Display (Stay tuned for a more detailed write up on this)
JVC 6.5" Splits Front
JVC 6.5" 4 way coax Rear
Both powered by a JVC 300w RMS amp mounted in drivers side rear quarter panel. Passenger side is filled up with rear air con unit.
Reverse Camera with over ride switch
Steel Mate 836G Alarm
I will go into detail more about the head unit etc in another post.
I will also upload some pics of it too.
