Page 8 of 8 FirstFirst ... 678
Results 71 to 77 of 77
Thread: Warn highmount rebuild kit
  1. #71
    483 Post(s)
    ............tp :-)
  2. #72
    The brace kit is worth it. There is a kit on eBay for $100 and you will need to find somebody to weld it.
  3. The Following 2 Users Say Thank You to Winnie For This Useful Post:
    MB (2nd July 2016), Rossco (2nd July 2016)
  4. #73
    Have a read through this thread Mark...
    http://www.nissanpatrol.com.au/forum...-mount-rebuild
  5. The Following 2 Users Say Thank You to Winnie For This Useful Post:
    MB (2nd July 2016), mudski (2nd July 2016)
  6. #74
    477 Post(s)
    Yeah I've read through that, and this thread. Just makes me wanna get one. But after todays drive, I really need to upgrade the intake first.
  7. #75
    I meant the other Mark! Haha. But you're welcome to read it too sweetheart
  8. #76
    334 Post(s)
    A couple of pics of my winch from the weekend. Tops off so thought of this thread.
    Here is a couple of pics of the Gigglepin (GP) brake shaft difference. It's far more than just a drilled and tapped shaft.
    The shaft also locks up the second Gear. The main gear is on the drum so the second gear is on the brake shaft.
    There is a packer that goes between the casing and the gear the the shaft has a rebate for circlip.
    There is zero play of the second gear on the shaft. Very cool.
    Also I have drilled and bolted the retaining plate to the case. I have had this plate fail on me once so this mod was a no brainer.
    Also VERY IMPORTANT. If you have rebuilt a Himount you will have a cardboard pack used to insert the oil seal. You should keep this in your spares kit and carry it. Essential if you have to strip your winch on the tracks!! I might have stripped mine n the bush a couple of times.!!
  9. #77
    483 Post(s)
    Cheers Daz, awesome info mate, really appreciated as I'm sure all will too:-) Touched base with Phil again yesterday morning and there's a slight delay on the Iskra motors arrival. Good news is he has a GP brake shaft waiting on the shelf for us also, rebuild dollars are climbing but worth it by the sounds of it !!
