Page 7 of 8 FirstFirst ... 5678 LastLast
Results 61 to 70 of 77
Thread: Long Range Petrol tank access issue
  1. #61
    84 Post(s)
    If it were my choice, I would go for an original pump. Look at how many vehicles have survived them over the last twenty five or so years. I don't like the look of the first strainer as it appears that the material can be sucked to close over the pick up if it becomes blocked over time.
  2. The Following User Says Thank You to mudnut For This Useful Post:
    dom14 (18th June 2016)
  3. #62
    Legendary dom14's Avatar
    38 Post(s)
    Quote Originally Posted by Bigcol View Post
    what about something like this for the fuel strainer.........
    http://www.ebay.com.au/itm/Brushcutt...-/221683320790
    not sure about the other one though, RB's are not my thing............
    Worth a try. May be too small for electric pumping. I won't know until I try.
    I'm ordering a one of this and one of the other and trial them first.
    Thanx
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
  4. #63
    38 Post(s)
    Yeah.
    I really like this one. Looks pretty sturdy.
    http://www.ebay.com.au/itm/121024647...84.m1436.l2649
    Burson sell the aftermarket pump, but that's the pump only. Same as the ebay link below, for $130 or so.
    It comes with a strainer as well, same as in the picture.
    http://www.ebay.com.au/itm/130982930...649&rmvSB=true
    I'm heading towards replacing the original pump and at the same time install another pickup for an external pump like this. I can have everything installed, including the external pump as a redundancy.
    That way, things can't get any better for a fussy wussy cheap butt like mine.
    http://www.ebay.com.au/itm/252333921...84.m1436.l2649
    I think I pretty much have it cleared which direction I'm heading now.
    I'll replace the original pump as well as install a redundancy external pump without costing a mortgage.
    What do you guys think about my plan?
    Cheetah Outreach
  5. #64
    38 Post(s)
    Hey Guys,
    I might have to use petrol resistant glue or sealant inside the tank for fitting in strainer & the extra pickup for the redundant pump line.
    Can you please recommend something durable and long lasting?
    I have epoxy and aviation sealant(Permatex). Permatex aviation sealant says it's gasoline resistant(but not alcohol resistant though). I just have to make sure to avoid ethanol added petrol, which I do anyway.
    I'm not too sure about epoxy resistance to petrol over time.
    Any advice on that?
    Thanx
    Cheetah Outreach
  6. #65
    38 Post(s)
    Cheetah Outreach
  7. #66
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    You've been busy.
    No need to reinvent the wheel. The fuel sender units work fine just the way they are and are perfectly safe.
    Electric fuel pumps need the sock/strainer to prevent crap being drawn in through the motor.
    I found this intank pump that claims to suit RB30S(Patrol).
    I'm not sure about how it would fit though. Picture they provided is not so helpful or convincing.
    Doesn't look anything like the pump I pulled out of the RB30 Patrol.
    http://www.ebay.com.au/itm/130982930...84.m1436.l2649
    This looks like the correct pump to me. Undo the metal clamp on yours that holds the pump to the sender unit and then have another look at the picture.
    edit Whoops didn't realise there was another page. Try Nizzbits for the strainer and fuel pump
  8. The Following User Says Thank You to Yendor For This Useful Post:
  9. #67
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Have you had a look inside the tank for the old strainer? Or for a reason why the strainer might not have been fitted?
  10. #68
    38 Post(s)
    BigCol told for some reason Nissan decide not to fit a strainer to some vehicle with internal tanks.
    I'm guessing, it may have something to with reducing the stress on the pump?!!
    I'm putting a new strainer anyway. They are cheap enough in fleabay.
    I had a look inside the tank. I couldn't find anything inside. BTW, bottom of the tank is pretty clean.
    No dregs that I can see. I bet the reason is that there's no strainer and the pump must have been
    sucking up all the gunk. Most likely the reason for pump intermittent failure or one of the reasons.
    What do you think about my choices with a petrol resistant glue/sealant. ATM, I have epoxy and aviation goo. Both apparently petrol resistant?!
    Cheetah Outreach
  11. #69
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    It should of had a strainer. I'm guessing when that tank was fitted they forgot to refit it or it's fouls on something within the tank (swirl pot??) and they had to leave it off.
    You won't need glue with the correct strainer and fuel pump.
  12. The Following User Says Thank You to Yendor For This Useful Post:
  13. #70
    84 Post(s)
    Truthfully, I think by the time you have all of your double redundancy devices in place, you will have twice the joins, wiring seals and equipment to go wrong.
  14. The Following User Says Thank You to mudnut For This Useful Post:
