Page 10 of 16 FirstFirst ... 89101112 ... LastLast
Results 91 to 100 of 155
Thread: TD42t Engine Upgrades
  1. #91
    I'm not sure Chappy's Avatar
    Jul 2014
    11 Post(s)
    @nissannewby can I get your thoughts on this? I just played around with my intercooler piping and noticed that one was extremely loose, as in finger tight on the clamp.. I've just tightened everything up and I'm positive it's much quicker. Would a boost leak like that cause such a massive difference?
    '96 GQ TD42t
  2. #92
    Quote Originally Posted by Chappy View Post
    Pressurised system Chappy. 100% yes
  3. The Following User Says Thank You to AB For This Useful Post:
    Chappy (10th June 2016)
  4. #93
    Jul 2014
    11 Post(s)
    That's awesome, I feel like I've just gained heaps of power for free. My clutch is really going to love me now haha
    '96 GQ TD42t
  5. #94
    Yes it will. You wont really see a psi loss as such but you are loosing volume. Volume is key to making the power and torque. When running these sorts of pressures and volumes good quality clamps are a must. Andy has been told which ones he should be using. Standard worm drive type clamps really dont cut it.
  6. The Following 3 Users Say Thank You to nissannewby For This Useful Post:
    AB (10th June 2016), BigRAWesty (12th June 2016), Chappy (10th June 2016)
  7. #95
    Jul 2014
    11 Post(s)
    I'll have to source some larger ones. I just have light duty ones currently. I'm really glad I found it.
    '96 GQ TD42t
  8. #96
    Matty, can you please advise those thin clamps you and Peter mentioned too as I forgot the name and I can't fit the wider angled bolt clamp style on my inlet.
    Might be helpful to Chappy too because I'm struggling on that side and just fit the bolt type on my turbo outlet.
  9. #97
    Worm clamps Chappy are no good mate on our beasts!!!!
  10. #98
    Jul 2014
    11 Post(s)
    It looks like I've got worms then... All of mine look like that apart from the big 2 on the intercooler itself.
    My new K&N filter arrived today. My Patroldocta box will be modified to fit it in. Helmet for scale.
    '96 GQ TD42t
  11. The Following User Says Thank You to Chappy For This Useful Post:
    AB (10th June 2016)
  12. #99
    These sorts of ones. Have a thinner 14mm band to make it easier than the 19mm band ones.
  13. The Following 3 Users Say Thank You to nissannewby For This Useful Post:
    AB (10th June 2016), Chappy (10th June 2016), Hodge (11th June 2016)
  14. #100
    Mar 2015
    these are the ones to use this is what we have on trucks we run 30 to 40 PSI but the amount of air that is moved is massive ......... i keep looking at the turbo in the workshop of a 15 litre cat and thinking can i shoe horn this sucker in
    oh and get spares they do still wear and break but not as near as much as the worm drives
  15. The Following 2 Users Say Thank You to Makka For This Useful Post:
    BigRAWesty (12th June 2016), Chappy (11th June 2016)
