Results 1 to 10 of 18
Thread: 2006 GU 4.2 oil filters
    May 2016
    8 Post(s)
    Hi all is there or has anyone found a way to catch the oil that comes out of the oil filters when changing them .
    I am new to this new toy . Just having a look . also where does the vacuum come from ? no pump on the back of the Alternator !
    when I get eneough posts up I can get a Manual . weeee
    177 Post(s)
    Someone on the other patrol forum built and sold a tray that bolts under the filters. Not sure if he still does it.
    I leave the oil to drain overnight and there is usually not enough left in the filters to make any mess.
    Otherwise I loosen the filter, then wrap it with a plastic shopping bag before I undo it completely and catch the oil in the bag.
    476 Post(s)
    Im lazy I just let it go everywhere, then hit it with the $2 SCA degreaser and hose off.
    Hodge (9th June 2016)
    I have one of these fitted to my GUIV and my GQ. They are made by Chicken on the other forum. is is a FIFO working and is on placement in Indonesia at the moment. Note sure if he has stock. You could try Matt at Pro-Deisel Motorsports on Facebook, he may have some stock of them.
    I rate it highly. I know Stropp also has one on his. Great bit of kit! They should be standard fitment.
    I also have a Chicken tray on mine, the only thing was I had to modify it to fit around the dipstick tube. But makes life so much easier.
    Mudski you really shouldn't let the oil drain over starter motor and wiring over time the oil damages the wiring insulation
    476 Post(s)
    It gets cleaned off with degreaser so its not on there long....
    I reckon the Chicken tray is a No Brainer.
  10. #9
    Chicken has changed his design, slightly different to mine.
  11. #10
    177 Post(s)
    So where do you order from this chicken bloke? I found his username on the other forum but no thread about ti ?
    Do you just PM him and go from there ?
