Results 1 to 10 of 10
Thread: Toyo uni joints
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    Toyo uni joints
    Hi guys what would you expect to pay
    for the rear drive shaft uni joints
    North brissy
    Around 50ea
    TRAFALGAR VIC
    35 Post(s)
    Around 50ea
    thanks Mat got quoted 65
    North brissy
    Quote Originally Posted by roofy View Post
    Threedogs might be able help you out with the price and all his contacts
  5. The Following User Says Thank You to nissannewby For This Useful Post:
    Ben-e-boy (6th June 2016)
    Might want to give Neil a buzz at Roo Dog spares
    http://stores.ebay.com.au/ROODOGS-4WD-SPARES
    Sir Roofy (6th June 2016)
    North brissy
    How much can you get them for?
  9. #7
    476 Post(s)
    Give Roadrunner a call roofy. They're not far from you.
  10. #8
    North brissy
    Any luck on those prices mate?
  11. #9
    TRAFALGAR VIC
    35 Post(s)
    Going to town tomorrow PatrolApart just down the road from Janes kids and grand kiddies
    usually get a good deal there
  12. #10
    3 Post(s)
    Advice before installing the uni's remove the caps and pump full of grease to remove all the air then put a bit of grease on the caps, then install. What can happen if you don't fill the uni's internal grease channel you can get a air lock, so when you goto regrease it one of the trunnion's will run dry.
    A quick and easy way of removing a uni from the tail shaft is a 9" angle grinder and cut it out then you can easily push the caps out of the yokes.
  13. The Following User Says Thank You to Snafu For This Useful Post:
    Sir Roofy (8th June 2016)
