Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: How I fixed the exhaust leaks on manifold & flange surface
    Legendary dom14's Avatar
    38 Post(s)
    This is what I did to fix the broken stud and leaking surface of the exhaust manifold and Y pipe flange.
    I also used high temperature copper sealant on manifold gasket even though it wasn't necessary as I sanded a surface
    perfectly flat.
    These pictures are self explanatory.
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
    38 Post(s)
    More photos
    Cheetah Outreach
  3. The Following User Says Thank You to dom14 For This Useful Post:
    growler2058 (8th June 2016)
    38 Post(s)
    This is where I used sanding boards and a make shift sanding table to flat sand the flange surface and manifold surface.
    BTW, make sure to wear a hankie over the nose or a mask. The iron dust starts flyng and you can end up breathing lot of it while sanding. I had black boogers coming out of my nose next day, I had to keep blowing my nose over and over in the shower. Also, it can make you feel bit sick.
    Cheetah Outreach
  5. The Following User Says Thank You to dom14 For This Useful Post:
    38 Post(s)
    Second lot of sanding pictures.
    Cheetah Outreach
  7. The Following User Says Thank You to dom14 For This Useful Post:
  8. #5
    38 Post(s)
    Third lot of sanding pictures.
    Cheetah Outreach
  9. The Following User Says Thank You to dom14 For This Useful Post:
  10. #6
    38 Post(s)
    Use new gaskets, or use a ceramic water based sealant between the two layers of the perforated metal gaskets, as well as both outer sides.
    For exhaust manifold I used the old gasket as it was still in good condition due to my use of exhaust sealant on it last time.
    High temperature copper sealant works fine with the exhaust manifold end gasket, but not on the exhaust flange(the temperature is way too high there).
    For the flange, water based ceramic sealant like Maniseal is the only solution(if not a brand new gasket).
    Cheetah Outreach
  11. The Following User Says Thank You to dom14 For This Useful Post:
  12. #7
    May 2016
    New manifold with turbo would have been on the cards if mine.
    There is no legal cure for STUPID!
  13. #8
    38 Post(s)
    Quote Originally Posted by LostBenji View Post
    I wouldn't wanna go turbo without EFI conversion & bottom end rebuild or a low km bottom end(if I can find a one).
    Cheetah Outreach
  14. #9
    May 2016
    on the RB30?
  15. #10
    38 Post(s)
    on the RB30?
    We're talking about RB30 Patrol, aren't we?!
    Cheetah Outreach
  16. The Following User Says Thank You to dom14 For This Useful Post:
    taslucas (6th June 2016)
