Page 1 of 7 123 ... LastLast
Results 1 to 10 of 64
Thread: GU GVM upgrade
    SHELLHARBOUR
    GU GVM upgrade
    Hi Folks
    I Have a GVM upgrade by Peders to 3.45T and need to go to 3.9T (I'm grosly over weight)
    It seems the Leaf spring rear axel allows that (both OME and Peders have kits)
    So this means changing from rear coil to leaf spring.
    Has any one done this and if so was it sucessfull?
    Regards
    Joe
    2010-DX Patrol Dual Cab Chassis, Front LOKKA, 3500kg GVM, 4.8 front brakes! (now stops like it should!), 4.625 Diffs (now drives like it should) 35"Mud tires, 3"exhaust, Rear air bags
  2. The Following User Says Thank You to JoeG For This Useful Post:
    Burgz (1st January 2018)
    334 Post(s)
    IMO it would seem far more practical and probably far cheaper to sell your current Ute and buy a Leafy Ex Telstra which will come with a GVM Upgrade, probably only to 3.4t but with the leafs already.
    3.9t is getting very heavy! especially for a Ute! what is your load? maybe an Iveco or something would be far better suited to your needs.
    SHELLHARBOUR
    Hi Mudrunner
    I've been running 3.9T for 5 years (thinging it was less) however the allowable load is 3.5T . my engineer will sign off on 3.9T with a leaf spring back end
    (OME ans Lovels have these off the shelf) hence why I want to do the conversion.
    My load is around 700KG but the extra fuel and water for central crossings bring me up another 200KG hence the need for 3.9GVM
    a single cab is not suitable as we need a dual cab or at least a extra cab.
    we have mucked around with lighter dual cabs and found them wanting and not reliable hence the switch to Nissan Patrol and it has not missed a beat
    all we need now is to raise the GVM and be legal
    Regards
    Joe
    Ballarat, Vic
    178 Post(s)
    All GU leafy utes have a GVM of 3400kg, not just Ex Telstra.
    Most GVM upgrades for these only increase GVM to 3700kg, Lovells is 3900kg but is not cheap, especially if a 4.2. (The Lovells kit approval is for 3L Patrols so requires 'engineering approval' for 4.2). All up mine was $5200 in 2013. $1200 was the engineers fees
    As for converting a coil ute to a leaf ute - I agree, probably cheaper & less drama to change utes. If doing that it may be worth looking for one with a gvm upgrade already.
    What cuppa said X 2
    IMHO it woud be simpler to get a Leafy Ute and upgrade to a King Cab or drop a wagon chop body on it.
    At 4 ton I would be looking at an expedition truck setup myself... those Ivecos are seriously awesome off road for example
    SHELLHARBOUR
    Hi Evil and Cuppa
    Yes I looked at the Toyota dual cab befor moding the Patrol
    Although the Toyota was a dual cab it needed a chasis streach and then a GVM upgrade so it could have a 2.4m tray and carry 1.1T
    The Iveco was not available at the time and is still questionable re service and dealer availability.
    So it seems a leaf spring conversion and a happy certifying engineer is the way to go.
    Possibly in 10 years time when the Patrol is at end of useful life (only use it for trips) we will look at a 5th wheel unit as mobility for us will also become a major issue by then
    Regards
    Joe
  8. #7
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    Talk to Paul at Statewide 4X4 (03 9484 7838). They laminate the rear diff housing on coil sprung Patrols to increase the GVM. Not sure how high they can go.
  9. #8
    They did mine as an ex ses vehicle.
    3490kg is it..
    Jul 2010
    Thurgoona
    7 Post(s)
    3490kg is it..
    OK. I hear they are developing new kits all he time. Won't hurt to call.
  11. The Following User Says Thank You to BillsGU For This Useful Post:
    BigRAWesty (7th June 2016)
  12. #10
    Jul 2010
    Thurgoona
    7 Post(s)
    It's worrying just how little weight most 4X4s can tow and carry legally. It's even more worrying how difficult it is to understand all the rules and acronyms they use when explaining why such a large vehicle as a Patrol can only tow and carry so little in weight.
    There would not be many Patrols out there towing reasonably large vans that are doing it legally.
  13. The Following User Says Thank You to BillsGU For This Useful Post:
