Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 48
Thread: Gu cruise control
  1. #31
    Quote Originally Posted by Dannyboyz View Post
    Just an update for anyone who is interested, on the control box for the AP60 there is a small loop of black wire with both ends running into the box, in the instructions it says that when using the magnets, if the speed that the CC engaged at is below 40kph, to either reduce the number of magnets or cut the black loop wire. As I'm trying to use the speed sensor and my cruise would only engage up as far as 45kph, so I cut the wire, now it has a max set speed of 94kph (GPS) however if I hold the set/acc button it will accelerate up to around 110kph then cut out. So I'm sure I can make it work up to 100 but I will have to ring Command and see if there is any further calibration that can be done on my end.
    If you are interested, check back for an update some time tomorrow avo
    By the way, it sits on 94 like a dream, cruise holds it steady as a rock
    Well that's sorta a win..
    Bit of a bugger..
    Hopefully some calibration can be done?
    Advanced Dannyboyz's Avatar
    Jan 2016
    Let's hope so, if not, I'll just think of the fuel I will save doing 94kph all the way through central Australia!
  3. The Following User Says Thank You to Dannyboyz For This Useful Post:
    BigRAWesty (2nd June 2016)
  4. #33
    Put on 35's.. then you'll be doing 106 ish..
    Jan 2016
    Ha ha, already rolling on 35s mate, maybe 37s? That could be the problem, with the GPS saying 94 the speedo is saying 102, I need my speedo to read 108 to be doing 100
  6. The Following User Says Thank You to Dannyboyz For This Useful Post:
  7. #35
    May 2016
    Make sure you are on straight & level ground for a KM before using the GPS reading. Anything else is biased results.
    There is no legal cure for STUPID!
  8. #36
    Jan 2016
    Ok mate, I used it the whole way home from work last night, about 20ks with a couple of small hills up and down, after every hill it would settle back to 94
  9. The Following User Says Thank You to Dannyboyz For This Useful Post:
  10. #37
    Think of the fuel..
    Think of the fuel..
    Lol
    Jan 2016
    That's it mate! 👍
  12. The Following 2 Users Say Thank You to Dannyboyz For This Useful Post:
    BigRAWesty (2nd June 2016), threedogs (2nd June 2016)
  13. #39
    Best bit of kit out there for an auto Patrol I reckon.
    had a CC in a RR we went to Cape York in,, this was back
    in 83 that had magnets on the tail shaft with no problems
  14. #40
    Jan 2016
    Ok sorry guys, phone had a nasty accident yesterday so couldnt get in for the update, official word from Command is I will have to put magnets on. Pulse is too fast out of my factory speed sensor
