Results 1 to 5 of 5
Thread: 1st Time Changing Oils.
    Beginner bushnbash's Avatar
    Jan 2014
    Gold Coast
    Sorry I couldn't find a sticky on this.
    Ok before I go and buy all the oils to attempt doing this are there any tips to make this job easier for a 1st timer. This is my shopping list.
    Rear Diff 2.1ltr Penrite Premium Mineral, SAE 140, API GL-5/6....
    Front Diff 5.4 ltr Penrite Premium Mineral, SAE 80W-90, API GL-5/6...
    Manual Transmission 3.9 ltr CASTROL MANUAL VMX-M 75W-85 & some Nulon G70 250gram for good measure.
    Transfer Case 2.2ltr CASTROL UNIVERSAL 80W-90
    Should this do the job?
    Cheers Paul
    P.S its a 1990 GQ TD42
    Feb 2011
    Shed
    45 Post(s)
    Get a good oil pump the thick gear oils are tough to put in with a cheap oil syringe and takes ages. A good pump straight on to the bottle will make life easier. Also undo the filler plugs first before you drain the oils they can be a bastard to get off
  3. The Following 2 Users Say Thank You to growler2058 For This Useful Post:
    bushnbash (20th May 2016), Hodge (20th May 2016)
    176 Post(s)
    Good advice. I use the Tom Thumb pump. But for thicker stuff like rear diff oil, I put the bottle of oil in bucket of hot water to thin it out a bit makes life a tad easier.
  5. The Following 3 Users Say Thank You to Hodge For This Useful Post:
    bignev (11th August 2016), bushnbash (20th May 2016), growler2058 (20th May 2016)
    Feb 2011
    Shed
    45 Post(s)
    I used the syringe type pump. Had a right bicep like a 13 year old boy by the end of it
    Aug 2016
    QLD
    Use a proper 13mm square male socket plug removal bit and not the half inch drive on a breaker bar. Supercrap does a kit for $40.
