Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Provent catch can leaking
    Jul 2015
    Camden NSW
    6 Post(s)
    Has anyone else had a problem with the drain valve leaking, the one supplied with the Provent catch can? I fitted my unit about 2 months ago and have been checking it weekly to see how much oil collects. I went to check it again last week and found oil over various steering bits. I don't think it was a lot of oil, but as you know, a little goes a long way. After checking further I discovered that it was leaking through the valve.
    To give them credit, I rang them up and explained the situation and they said they would replace the valve asap. Has anyone else had this happen and were they happy with the replacement, or did they replace it with a different valve.
    177 Post(s)
    Put some plumbers tape on the threads at the valve. Solved.
    I went though the same saga.
    Jul 2015
    Camden NSW
    6 Post(s)
    Thanks Hodge, but my one's leaking through the valve. I tested it by putting some oil in the catch can and watched it leak out through the valve. A steady drip.
    177 Post(s)
    Your valve comes apart yeah ? 2 parts joined by threads?
    Sorry should have mentioned that'd where my oil leaked through.
    477 Post(s)
    Which valve are you talking about? Can you take a pic?
  6. #6
    177 Post(s)
    Ok this is the type of valve I got through Western filters Provent200 kit.
    I initially thought the whole valve was "one" part. But the bit I circled in yellow where the hose attaches to actually screws out.
    And the oil was leaking through the threads on that part.
    If this is the same type of valve you have, this may be yours cause.
    477 Post(s)
    That part circled is an air fitting say for a rattle gun. Why have they given you this rsther than a proper barb fitting.
  8. #8
    177 Post(s)
    Yeah it's a fitting seen on air compressors. I think the valve it's self is some sort of an air valve too.
    Just came part of a kit with the catch can. And it worked (except the leak).
    Jul 2015
    Camden NSW
    6 Post(s)
    Guys,
    Mine is the same valve except it has a brass barbed fitting. The leak in mine is through the valve, as if it was turned on, but only a steady drip in the off position.
  10. #10
    sunshinecoast
    3 Post(s)
    i did not get a valve with mine . i just went to bunnings and got a irrigation tap with barbs on it for about $2 . never leaked a drop in 3 years .
  11. The Following 2 Users Say Thank You to nipagu7 For This Useful Post:
    AD07 (17th May 2016), sooty_10 (16th May 2016)
