Results 11 to 20 of 38
Thread: 20+ Psi coasting
    177 Post(s)
    I just read this... my boost was doing exactly the same before taming it with the dawes and needle setup after getting the exhaust fitted .
    It was having spasms and best description was a yoyo effect.
    After Mudski helped me set it all up it was so much better to drive smooth boost curve.
  2. The Following User Says Thank You to Hodge For This Useful Post:
    GUDriver (19th May 2016)
  3. #12
    Quote Originally Posted by trekster View Post
    When I blocked my egr and put 3" exhaust on, without boost control, The ecu couldn't control the boost and if I was just cruising with bugger all foot down the boost would go up to like 25psi+ If I put my foot down there was no problem it would drop back, but couldn't cruise at all.... Might want to check your boost control setup assuming you have a dawes/tilix etc.
    Still ecu controlled..
    Bugger..
    I was sorta hoping I wouldn't have to go that road..
    I'm actually liking the boost smart boost actuator conversion..
    Might research more..
    Quick Q. Did you guys get the readings off manual gauges or did you notice boost spikes threw scangauge with corrected boost reading?
    I'll swap it to the manifold pressure on the scangauge and see if it's going off chart or if it is just the scangauge miss calculating..
    I can't hear any turbo spool up when is saying 20+ Psi, like I can when I sink the boot in and it hits 15..
    Patrol Freak trekster's Avatar
    Nov 2012
    Coffs Harbour, NSW
    For me both, Boost reading on torque would flash at 22psi so it couldn't go any higher, my old turbosmart gauge went to 25 and was off the chart a couple of times lol.
    1998 GU RD28T: RIP
    1996 GQ RD28T: RIP 11 days later
    Hello 2012 GU CRDZD30
    Nissan winchbar + Warn, Dual Battery/Redarc, UHF and Titan rear drawers
  5. The Following User Says Thank You to trekster For This Useful Post:
    BigRAWesty (12th May 2016)
  6. #14
    So I've flicked the scangauge to Manifold pressure and it's not as bad as first thought. .
    At 110km/h pressures were between 25 and 33 psi..
    So under full load it was 30..
    So yes still a little over but not double as the corrected boost reading was..
    So..
    I'm thinking current exhaust is still to loud..
    So I'm thinking I'll be putting a cat in the dump pipe........
    That may add the little back pressure needed to control the run away spool..
    If not then I guess I'll need to look at manual controls..
    oh so the car is sticker material....No cat hey...what will the mrs say
  8. The Following User Says Thank You to Avo For This Useful Post:
    BigRAWesty (13th May 2016)
  9. #16
    It is it is..
    She know..
    She likes the exhaust.. it sings around town..
    Just a touch of a pain on the open road..
    477 Post(s)
    Yeah my thoughts too. Nice fine if your caught without a cat too.
  11. #18
    Yeah I've never understood why folk wouldn't put one back in and risk the sizeable fines, just get a hiflow jobbie so they can tell uncle plod. .... look its got one
  12. The Following User Says Thank You to Clunk For This Useful Post:
    BigRAWesty (2nd June 2016)
  13. #19
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Hey it's Westy we're talking about here
    ________________________
    ______ 2017 D-Max _______
  14. The Following 3 Users Say Thank You to Maxhead For This Useful Post:
    Avo (14th May 2016), BigRAWesty (2nd June 2016), Clunk (14th May 2016)
  15. #20
    477 Post(s)
    Yep I had a high flow metallic filled cat when i had the 3ltr. Seemed pretty good to me. Not sure of the power difference it would have been without the cat but it was one thing i didn't want to risk.
    I got checked twice in the time i had it by the rta. In the same spot too.
    Both times the first thing they looked at was under the car at the exhaust.
  16. The Following User Says Thank You to mudski For This Useful Post:
