Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: EGR plate/Blocker
    Cant say for sure coz I drive a TD42, but if th RD28 is like the ZD30, then maybe the computer needs to relearn..... I think disconnecting the battery resets the computer.....
    Hipefully some of the more knowledgeable members will chime in
    bwhaaaa....is that hippyfully...you need more shrooms...
  2. The Following User Says Thank You to Avo For This Useful Post:
    growler2058 (8th May 2016)
  3. #12
    Need more than shrooms mate
  4. #13
    Advanced damian.thomas's Avatar
    Apr 2016
    Thanks for the reply cluck but no luck. Does anyone know if exhaust gas was leaking from the egr it would cause my car to rev out under more pressure?
    Cheers Damo
  5. #14
    Id say its revving out more because its getting fresh air now rather than a mix of fresh and soot filled air.
    00marshall (4th February 2017)
  7. #15
    Guessing it's an auto?
    Di or crd?
    Any gauges?
    When blocking the egr you get a slight increase in turbo spool up, due to now 100% of exhaust gas going threw the turbo..
    This sometimes causes limp mode, if the turbo spools up too quickly or its picked up no flow in the egr.. both can throw fault codes..
    Try drilling a small 6mm hole in the blacking plate.
    A smear or stag paste or gasket goo to make a new seal, disconnect battery with lights left on for a couple of hours to reset the ecu.
  8. The Following User Says Thank You to BigRAWesty For This Useful Post:
  9. #16
    Di or crd?
    Any gauges?
    The 2.8's wont go into limp mode due to the EGR blocked. So drilling a hole will be pointless. But if it is leaking at the plate, check the surfaces to make sure they are flat, gasket goo as mentioned may help. The RD28 EGR valve is vacuum controlled, not electronic. So disconnecting the battery may be pointless. But its worth a shot.
    And to add. The RD's have a pressure relief valve on the intake manifold, because you have blocked the EGR, boost pressures will be higher so all that extra pressure may just be going out the relief valve. I have heard of people removing this valve and blocking the port on the manifold. But you will also need to install a manual boost control valve then to control your boost pressure.
    Having said that I feel this may be your issue.
    BigRAWesty (10th May 2016)
  11. #17
    Augh. Good pick up lol..
    I gotta stop posting at 3am...
    But good advice on the relief valve. A recent member had a faulty one and it was just by passing when on boost..
    I'd say check what mark has suggested..
    And a boost gauge and controller..
    Yeah thats what reminded me. Was an overseas member i think.
    BigRAWesty (11th May 2016)
  14. #19
    Apr 2016
    Thank you for all the replys guys, got some copper gasket silicone today so i might pull it to pieces tonight and glue it up. Next will be a manual boost controller, gauge and egt if it doesnt work.
    Cheers Damo
  15. The Following 2 Users Say Thank You to damian.thomas For This Useful Post:
    00marshall (4th February 2017), BigRAWesty (11th May 2016)
