Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Starter motor on it's way out?
    Jul 2014
    6 Post(s)
    Hey, I've got an rb30 GQ manual.
    When I turn the key, the motor doesn't turn over straight away - I get a slight whirring sound, but not the normal starter sound. I then get a loud clunk, followed by the starter turning normally and the motor starting.
    I've swapped batteries to rule that out, and the connections to the starter are good.
    Does this sound like an issue with the starter motor?
    477 Post(s)
    The solenoid could be sticking. Give it a few taps with a hammer see if this helps. I remember my old MK had similar issues. I removed the solenoid and pulled it apart, cleaned it up and lubed up the solenoid piston, if you call it that, with some lmm grease and was all good.
    Sounds like the solenoid is not throwing it out properly, so yes starter probably needs some love or replacing.
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    Agree with Rossco and mudski, but important to do it as it could chip or damage teeth on the ring gear on the flywheel.
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Yeah, Agree with the guys above. Remove the starter motor and lube the plunger in the solenoid and the pinion gear on the the shaft in the starter motor.
  6. #6
    Smack it wiff a 'ammer... worked on every Holden I ever owned.
  7. #7
    Jul 2014
    6 Post(s)
    Thanks guys. She's due for some love anyway. Still have to find my disappearing oil leak.
  8. #8
    84 Post(s)
    And after you've done that, give the starter motor a smack with the hammer too
    Please give me feedback on how you removed the RB30 starter, TH, as well as what you did to repair it.
    That way I can post it in the sticky thread.
  9. #9
    Jul 2014
    6 Post(s)
    No worries mudnut, will do. Might be a while until I get to do it though.
  10. The Following User Says Thank You to Throbbinhood For This Useful Post:
    mudnut (11th May 2016)
  11. #10
    Legendary dom14's Avatar
    38 Post(s)
    Quote Originally Posted by Throbbinhood View Post
    What disappearing oil leak?!
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
