Page 40 of 44 FirstFirst ... 3839404142 ... LastLast
Results 391 to 400 of 434
Thread: Threedogs motor thread
  1. #391
    It's never normally just the head gasket. You can almost guarantee the head will be cracked.
    Yep 100% agree. I would be lining up a new head without question.
  2. #392
    If the gasket had broken else where I would have water in the oil.
    Its not cost effective to replace the gasket Ive had quotes from
    $6k-$10K , Cheaper to replace the motor as Mudski said
  3. #393
    This is crap. Absolute crap.
  4. #394
    Dont you think its a motor out job to replace the head
    then you have to changeover most of the gear, probably
    a bit of machining I dont know
  5. #395
    No. Can be done in situ. Sure it would be easier with it out but no machining required.
  6. The Following User Says Thank You to nissannewby For This Useful Post:
    threedogs (9th May 2016)
  7. #396
    Whats crap these are two quotes from 2 leading 4x4 shops in Melb
    or did I miss something
  8. #397
    6-10k to replace a head is crap. More like 6-10k for drive in drive out engine replacement.
    For someone who goes on about being in the industry ypu surely could get the head replaced for 2k or less. 3k at the most.
  9. The Following 2 Users Say Thank You to nissannewby For This Useful Post:
    trekster (12th May 2016), Winnie (9th May 2016)
  10. #398
    Have you even priced that exercise its a motor out job
    and from what Ive gathered a heck of a lot of labour involved.
    its after all a ZD30
    I've done it before on a surf, at home and for under $2k new head and all bits and pieces. Then I was told that my overheating was due to a crack in the block. Got a reconditioned bottom end for $3k and it still overheated, then I sold it.
    Sorry mate, but I really don't know what else to say.
    This is why I didn't want another diesel, especially one that is prone let go.
    I'm happy with my gas blower, cheap to run and strong as nails.
    Sent from my XT1033
  11. #399
    Oct 2010
    Old Bar, NSW
    As suspected I have blown the head gasket between the water channel and the compression chamber.
    That is why the cooling system is pressurizing,
    I have not blown the gasket between the water channel and a oil line , as Id have water in oil
    which I dont.
    I admit to not knowing a lot about these engines, for you to keep blowing hoses etc there must be a pressure build up.
    Main place to get that sort of pressure is from a pot? Reckon there is a head gasket or some other passage allowing pressure in the cooling circuit.
    You seem to be like a cartoon character who has run out of hands trying to plug the leaks, stop one and another starts.
    Not much help I know, just feel you are not in the right area to find whats wrong, fixing the result not the cause.
    Lucky guess...
    At least you have found it now.
    Macca
  12. #400
    Yeah, thinking back, your right here.
    Sent from my XT1033
