Page 5 of 8 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 73
Thread: Can i get a mechanical injector pump for 4.2gq
  1. #41
    177 Post(s)
    Quote Originally Posted by landy96 View Post
    Sorry whats an( afaik )
    As far as I know
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    simple suggestion to a complicated question
    strip all the extra crap off
    take the cooling system back to standard
    standard Thermostat (starts to open when it should, be completely open when it should)
    new Fan & Viscous hub
    remove your sock - they are for feet - or 1950's cars, not modern motors
    use Nissan Coolant - NOTHING else
    then take it to a Diesel Mechanic and get it dyno tuned
    if the pump timing is out - your wasting time ginning around with possible maybe this or maybe that
    also
    instead of passing small amounts if information every now and again with your posts in 2 threads
    start the story, and write it all completely, so we CAN help
    sorry if I sound rude - but this is annoying trying to help with little bits or NO information
    like trying to draw teeth out, and I am not a Dentist
    PLEASE
  3. #43
    Hardcore
    central coast nsw
    AFAIK blocking the thermostat bypass is an old school thing for a different cooling circuit...
    Doing it/trying it on a ZD30 might prove pretty spectacular.
    I haven't seen it done but thats because cooling isn't nearly the issue with ZD30's that it is with TD42's
    Maybe someone has done it and can post up...
    Isn't the thread "Can I for TD42" only
    Or did I miss something.
    Yes the bypass ideas for the TD42 only.
    I haven't tried it so I can't say one way or the other, just passing some info on, that might help ya out.
    IF IT'S NOT A NISSAN.
    THEN IT'S A COMPROMISE
  4. The Following User Says Thank You to Robo For This Useful Post:
    Maxhead (5th May 2016)
  5. #44
    No and Yes...
    Landy has a ZD with cooling issues and there are threads that are now all tangled together about ZD cooling, ZD mech pump, TD42 mech pump and his frustration with the vehicle and other options (I think)... it has gotten very confusing...
  6. The Following 3 Users Say Thank You to the evil twin For This Useful Post:
    BigRAWesty (5th May 2016), LostBenji (19th May 2016), Robo (5th May 2016)
  7. #45
    Hardcore
    central coast nsw
    No and Yes...
    I replied to this TD issues thread, and this thread only.
    Haven't seen, read, his other ones.
    Not having a shot bro, actually lol about it, can't be every where.
    Honestly though, now Iv'e stopped laughing.
    If only the thread had been,
    " what if hypothetically speaking I had a different motor".
  8. The Following User Says Thank You to Robo For This Useful Post:
    the evil twin (5th May 2016)
  9. #46
    snip...
    ROFL... me neither cobber.
    When I'm having a go the post starts out as;
    "Why #$@% the %$^&# you #$%&* buy a Prado $%%@ stupid *%$^*&"...
    and goes downhill from there.
    Landy does have a bit of strange problem tho, hope we can help him sort it without having to transplant him into a GQ TD42 with an aftermarket Pump... Fuel pump that is...
  10. The Following 2 Users Say Thank You to the evil twin For This Useful Post:
    Bigcol (5th May 2016), BigRAWesty (5th May 2016)
  11. #47
    Hardcore
    central coast nsw
    Well as Shultz would say , Me know nothing, well about zd cooling anyway, so this is where I bow out.
    Sorry I couldn't help.
  12. The Following User Says Thank You to Robo For This Useful Post:
    the evil twin (6th May 2016)
  13. #48
    Advanced landy96's Avatar
    Mar 2016
    Brisbane 1 week. 2nd week home millmerran
    Shit hit the fan the other day . We were going up the range heater on overdrive off.no trailer.no load.empty.we thought not a problem . Ha ha .
    Nissan gauge just below half .aftermarket gauge 87 where it sits normal.going up hill temp creps up going 40kph gets to just below 100 .nissan gauge hasnt moved .. wifes driving she pulls over to let it cool .goes down to 87 off we go again .same shit twice more . Third time truck up her ass temp goes up and up she abuses me i abuse her nowhere to stop temp goes to 110 very bad abuse from both partys as we stop heat from heater is boiling us . But wait nissan gauge has hardly gone up a tiny flyshit. It shows no problem while motor is boiling . No wonder first motor blew . After cooling we took off again .both sides sorry for what was said . Needless to say one gu up for sale were buying an older swb xlt petrol on gas auto 1990 model . sorry guys but thank you for all the help and suggestions .
  14. The Following User Says Thank You to landy96 For This Useful Post:
    the evil twin (8th May 2016)
  15. #49
    Legendary happygu's Avatar
    Thousands of 3 Litre Patrols out there that don't overheat .... gotta get to the root cause of the problem and taking it to an expert could definitely be helpful in this situation.
  16. #50
    Yep.. something is not well..
    This massive 4 core radiator you bought..
    Is it a quality brand name or some ebay $100 buck job?
    Some ebay ones have been known to cause more harm than good with extremely poor flow..
    Have you checked your water pump at all??
    Imo remover the sock.
    With a well maintained system I can't see the need..
    I know 5 cars personally and owned one of them with half a million or more kilometers on em and never run a sock and never had blockages..
    Regular services prevent this..
