Page 29 of 44 FirstFirst ... 2728293031 ... LastLast
Results 281 to 290 of 434
Thread: Threedogs motor thread
  1. #281
    There is a small hose that has split after
    I repair that Ill get my mate onto it.
    I need to be mobile, bottom line
    Just so no one else asks I WILL be getting it tested.
    but first I need it here not 20ks away.
    Then repair that hose so at least It will be running to test
    I acuatally lined up the mechanic last time it was apart
    Yet I can drive to the city and back with no dramas.
    Oh well
  2. The Following User Says Thank You to threedogs For This Useful Post:
    BigRAWesty (28th April 2016)
  3. #282
    Make up your mind John. Is it coming from the thermostat housing or a split hose?
    This thread makes my head hurt.
  4. #283
    477 Post(s)
    Hoping it is that small hose. If and when you get it off check the steel pipe for corrosion. Going by the brown colour on the inside of your hoses when i was there. It wont surprise me if the pipes are corroded.
  5. #284
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    nI would like a $ for every time we have replaced a pert in a pressure system here at work, only to "blow out" the next worn pipe or hose.
  6. The Following User Says Thank You to 4bye4 For This Useful Post:
  7. #285
    That was because a known 4x4 shop owner who helped here a few years back
    did not put coolant in my motor, I did not notice till it was too late.
    if not the owner it was his off sider. why do you think I never go there anymore
    wouldnt take my lawn motor to them.
    I may have brown in the pipes but I dont think any well hope not are corroded
    find out soon enough
  8. #286
    Winnie unfortunetly I dont have xray vision like you .How the hell would I know where its leaking from
    wierd question Ill need to remove a few bits and pieces first to get to the area
    I scanned a photo of the motor and I assume its coming from that hose.give or take
    Sorry about your head hurting, may I suggest an Aspro and a lie down.
    Mark knows how hard it is to get into these motors. Im getting the Patrol
    tilt trayed to my place tomorrow and will pull it down over the weeekend
    if any one feels like helping that would be great, not a big job just fiddly
    Great post too Winnie real helpfull, i can use thermostat housing and split hose
    Nope cant use any others LOL LOL LOL
  9. #287
    John, have you tried disconnecting the battery for 24 hours?
    Sent from my S50 using Tapatalk
  10. #288
    Last resort and clean the Maf , Ill also invert the tow bar lol
  11. The Following User Says Thank You to threedogs For This Useful Post:
    rusty_nail (28th April 2016)
  12. #289
    It fixes everything else right?
  13. #290
    Its a mighty ZD30 what could possibly go wrong.
    famous last words.
  14. The Following User Says Thank You to threedogs For This Useful Post:
