Results 1 to 3 of 3
Thread: GQ Pitman arm question
    Expert Lawrence's Avatar
    St Thomas, Jamaica
    Hi guys. I took my Patrol to the alignment stand today. Apart from tie rod ends, they said I also needed a pitman arm. My mechanic say he thinks they meant drag link as the ball joint would be a wear item. Do Pitman arms wear on a Patrol? I have never heard of them being replaced here. Only the drag link and tierod ends. What would be the symptoms of a bad pitman arm?
    1989 Nissan Patrol DX with the td42 (inline pump). No mods yet except black US 16x8 rims with 265 75 16 Ats
    477 Post(s)
    The only way I can see a pitman arm needing to be replaced is if the spline is shot at the steering box end, the tapered hole is shot at the drag link end or the arm is physically broken. I would assume the mechanic is meaning the drag link. Get the mechanic to point at the item he means....
  3. The Following User Says Thank You to mudski For This Useful Post:
    BigRAWesty (27th April 2016)
    St Thomas, Jamaica
    Thanks. i agree with that. i called them back and they confirmed it was the drag link Ordered one today.
  5. The Following User Says Thank You to Lawrence For This Useful Post:
    mudski (28th April 2016)
