Page 12 of 16 FirstFirst ... 1011121314 ... LastLast
Results 111 to 120 of 154
Thread: Robo's ride
  1. #111
    Hardcore
    central coast nsw
    Took the alloy bar off for the last time, to trim it a tad more and connect wiring to winch.
    very happy with the outcome,
    now time for a break away for a few days.
    will then be connecting the wiring in cab next week.
    DSCF8273.JPG.
    Safe ANZAC weekend peoples.
    IF IT'S NOT A NISSAN.
    THEN IT'S A COMPROMISE
  2. The Following 3 Users Say Thank You to Robo For This Useful Post:
    Clunk (3rd May 2016), MB (22nd April 2016), MudRunnerTD (1st December 2016)
  3. #112
    Hardcore
    central coast nsw
    Humm, looking at the wiring on solenoid something could be wrong.
    The factory fitted cables to the solenoid ,which are colour coded, are not connected to the numbered post as the manual states.
    Yellow is on post number 1, & Red is on post number 3.
    But manual clearly shows and written, has them the other way around.
    I rang supplier and they said, its ok we test every winch.
    but I' not so convinced the solenoid is tested also, every nut and bolt has not been touched ex factory ie-not a mark on em.
    Any input welcome, have no experience with this type of solenoid before.
    Its a Domin8r 12000lb winch package
    DSCF8583.JPG.
    Well I rang em again, hoping to talk with someone else.
    This time
    Quote
    "yes the instructions are clearly wrong it's also covered buy a 5 yr warranty, your covered , fit it as supplied and it will be ok ( don't you guys test winch on a test bench) no we even test the solenoid with the winch" end quote.
  4. #113
    334 Post(s)
    I can't see the pic clearly on my phone but it is likely that they are F1 & F2 anyway so they will just be direction and there is no risk to anything.just the switch direction.
  5. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    Robo (2nd May 2016)
  6. #114
    Hardcore
    central coast nsw
    Yeah I had that line of thought also.
    My fear was connecting in a way it should not be, and I'm multiplying a potential problem by increasing the cable size to 50mm from 35mm square.
    Any way of a breaker or something in the install ?,
    I have not seen anything available.
    I've updated the previous pics
  7. #115
    334 Post(s)
    This is the solenoid you have there I think and is the same one I have on my GUIV.
  8. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    Robo (3rd May 2016)
  9. #116
    Hardcore
    central coast nsw
    Yeah it looks the same going by the pic. thanks for that.
    I cant seem to click on the pic to enlarge it, to read the fine print.
    Gota de-clutter some wiring that has accumulated around the battery first looks crappy at the moment.
  10. #117
    334 Post(s)
    Here it is again, I tried to get a better source image.
    Here is a screen zoom on my iPhone from the original image on the forum.
  11. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    Robo (3rd May 2016)
  12. #118
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    13 Post(s)
    Does this help at all?
    John
  13. #119
    Hardcore
    central coast nsw
    MR to the rescuuuuue
  14. The Following User Says Thank You to Robo For This Useful Post:
    MudRunnerTD (3rd May 2016)
  15. #120
    Hardcore
    central coast nsw
    Yep it helps.
    So much so I saved your winch build pics a while ago for ideas for Pat
    My Hid boxes are stored in that hole, may locate near brake booster me thinks.
    from memory I approximated "your" cable measurements also.
    So thanks to you also.
  16. The Following User Says Thank You to Robo For This Useful Post:
    jff45 (3rd May 2016)
