Results 1 to 8 of 8
Thread: Catch Can Block..???
    Feb 2016
    Hi Guys,
    I just purchased a Provent (knock off) from eBay , obviously plumbing the inlet and outlet are simple , but im just wondering as the kit comes with no hoses, how anyone that has one went about blocking the 12.5mm drain hole.??
    I was thinking maybe a clamp, piece of hose and a small ball valve or something similar.......any help or info much appreciated.
    Cheers,
    Ad.
    Get some 1/2 inch hose and run it down the chassis rail. Put a ball valve tap on it so you can drain it with ease. Thats how I have mine. Its runs down in between the inner guard and chassis rail and sits over where the sway bar mount is on the chassis rail.
    AD07 (21st April 2016)
    Same with mine.. easy to drain.. easy to see..
  5. The Following User Says Thank You to BigRAWesty For This Useful Post:
    Expert Daveyboyjunior's Avatar
    Feb 2015
    Dartmoor, England
    Yep, just the same. Extended down into the wheel arch area against the chassis rail, with a tidy external cap on the end.
  7. The Following User Says Thank You to Daveyboyjunior For This Useful Post:
    BigRAWesty (22nd April 2016)
  8. #5
    sunshinecoast
    i just went to bunnings and got a irrigation valve with barbed fittings moulded in for a couple of bucks , works perfect , never leaked a drop .
  9. #6
    Feb 2016
    Quote Originally Posted by nipagu7 View Post
    Sounds like a plan.....
  10. #7
    Apr 2016
    should do the trick
  11. #8
    Aug 2010
    adelaide
    this is mine
    OH LEATHER IS NICE
  12. The Following User Says Thank You to my third 256 For This Useful Post:
    AD07 (26th April 2016)
