Results 1 to 10 of 11
Thread: Better fuel economy zd30
    Advanced landy96's Avatar
    Mar 2016
    Brisbane 1 week. 2nd week home millmerran
    How do i get better fuel economy.
    I have just replaced my engine with a used one and fitted a dawes and needle valve egr block catch can egt and boost gauge .. used motor came with reco injector pump nothing else . Used all original parts from before. Before swap over . Highway travel
    600ks to 3/4 tank
    500ks to 3/4 tank towing
    Now getting
    500ks to 3/4 tank
    400ks to 3/4 tank towing
    Which way do i go with needle and dawes valve ?
    Set to 18 psi max boost bounces to 20 for a second . Can the injector pump be adjusted still in car (and can i get a mechanical pump not using computer ? )
    2002 gu zd30 auto
    Enjoy The Journey
    Dont Be In A Rush To Reach Youre Final Destination
  2. The Following User Says Thank You to landy96 For This Useful Post:
    MEGOMONSTER (23rd April 2016)
    Not much you can do its only a 3ltr,
    what tyres have you got?
    What tyre pressures do you run?
    Do you have a roof rack?
    18psi is high but acheivable
    Has this motor had the intake cleaned?
    too many questions imo
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    I am no expert on these at all but I have noticed on our work vehicles, a Kia Truck, Vito van and Pregio van, that different injector pumps change the engine characteristics completely. Another thing affecting ltrs per hundred can be leaking or blocked exhausts. as I say i am not an expert but just offering as a starting point as you said you have a new motor with a reco injector pump.
    I might add do you have the original intercooler if so its more than
    likely leaking and in need for a tigged one, Your old motor was pushing
    very good figures, I get very similar.
    Plus check all the vacuum hoses they could be cracked and brittle if OE..
    no 2 motor are the same but I think you can get similar figures with a few tweaks
    Mar 2016
    Same tyres same roofrack same intakepipes new larger tigged intercooler new maf sensor .goes into limp mode just before fully warmed up no other time ??
    Expert Ronin's Avatar
    Brissy
    Some guys have reported that changing the fuel rail pressure relief valve has improved the economy considerably. The initial symptom is it takes a few tries to start a hot engine.
    2012 GU Patrol Simpson Edition. Auto. UHF, Bull Bar, 2" lift with Koni shocks, dobinson coils. 3" stainless Steel Exhaust.
  8. #7
    Bummer but hate to say it but that newer motor is not as good as the one it replaced.
    No two motors are never the same eh You may need to Tune this motor to suit the way
    its set up. Go get a Dyno is all I can say that will get the best from what you have IMO
  9. #8
    Mar 2016
    Where is the cheapest place in brisbane southside for a dyno
  10. #9
    So those figures are a pita..
    Throw some actual k/L figures so we can fully understand..
    By the sounds of your rig and being an auto 13-15L/ 100k is not unreasonable.
    Not sure how much can be tuned on the zd30 as its majority ecu controlled..
    Did you reset the ecu once the maf went in?
    Mar 2016
    Ecu was reset
    Landy96 is abit slow but
    Lost 100ks per tank after bare motor swap . No leaks new welded intercooler
