Page 18 of 44 FirstFirst ... 1617181920 ... LastLast
Results 171 to 180 of 434
Thread: Threedogs motor thread
  1. #171
    What I think I have is some stuff I can put in the old thread
    let it harden and then just re tap it, but I think a heli coil
    would be a better fix, No rush now lol
    Is it called chemi weld or similar
    No no no.
    Helicoil or Mark's housing.
  2. The Following User Says Thank You to jay see For This Useful Post:
    mudski (15th April 2016)
  3. #172
    476 Post(s)
    No no no.
    Yeah dont cut corners John... Helicoil will work fine.
    jay see (15th April 2016)
  5. #173
    Cool ,all work was done using a 3/8 socket set either that
    or my 1/4 drive set I had,
    Mark hasnt got a housing has he John??
  6. #174
    I do have this other housing here mate. I can shoot it across sometime tomorrow. Unless someone is going past Mill Park to your way.
    That would be awesome Mark when
    I repair my one Ill drop it back to you.
    Sorry didnt see this earlier
  7. #175
    Can anyone confirm if that chemi weld putty would be up to the task
    As far as I know chemi weld goes in the radiator.
  8. #176
    Yeah must of got the name wrong doesn't matter now as we wont be using it,,,,,lol
  9. #177
    Bumped for any takers please...........
  10. #178
    Patrol Guru paulyg's Avatar
    Ballarat
    Don't know about the chemi weld, JB weld might work.
    2010 TB4.8, 5 speed auto TI Wagon, Beaudesert ceramic coated Extractors and 2 1/2 inch exhaust, 3inch lift, BP-51 shocks, Black hawk radius arms and drop boxes, Road Runner Offroad billet alloy draglink, Boss air bags, 295/70/17 KM3s, Redarc Gauges, GME XRS UHF, Autometre fuel gauge, Alpine head unit with offroad maps, Carbon winch, Opposite lock bull bar, Light Force Strikers, Safari Snorkel, Duel long range tanks, work in progress.
  11. #179
    If you want to fill, drill and retap then Devcon is the go... we used it in the RAAF and that shit is awesome.
    Can be drilled, tapped or machined
    Even rebuilt a busted water pump housing with it on my Ski Boat years ago
    but....
    it isn't cheap and would be only if you cannot get a housing thingy
    http://www.devcon.com/prodfiles/pdfs/fam_tds_107.pdf
  12. #180
    Quote Originally Posted by Kimbo63 View Post
    Could you tap it out to 10mm John might get you out the sh|#
    Don't think that would work.
    The holes that are on the engine housing would need to be drilled out bigger. Probably could as a last resort.
