Page 17 of 44 FirstFirst ... 1516171819 ... LastLast
Results 161 to 170 of 434
Thread: Threedogs motor thread
  1. #161
    Patrol Guru Kimbo63's Avatar
    Dec 2015
    Perth WA
    5 Post(s)
    Could you tap it out to 10mm John might get you out the sh|#
  2. #162
    Yeah, what a pita, would have it had it going for sure, much easier the second time around. John has a 5/16th helicoil but no bolts. I had to leave to do the school pick up. He is looking at a couple different options.
  3. #163
    Was it loose?
  4. #164
    476 Post(s)
    Was it loose?
    Sounds like the thread stripped and wasnt holding the housing on tight enough.
    threedogs (15th April 2016)
  6. #165
    Was it loose?
    Both bolts were done up using a 3/8 drive with a small extension, couldn't get enough leverage. Put a longer bar onto it and got another 1/2 - 3/4 of a turn, then did the other one and it pulled the thread.
    Felt guilty leaving him like that.
  7. #166
    Yeah I would say the bottom bolt could've been tighter.
    I have a gazillion tools here so my son is scouting around his mates
    which most are in the Auto trade, and maybe he can pick up
    a couple of heli coils fo me
    All good John as I said two dissimilar metals causes corrosion
    Plus they fuse themselves together, worked on alloy motor bikes
    for way too long to worry about a stripped thread. we can repair it
    and stronger than new
  8. The Following User Says Thank You to threedogs For This Useful Post:
    jay see (15th April 2016)
  9. #167
    So my hopes of being ready so I can see my surgeon on Tuesday morning have been dashed.
    Oh well will have to taxi it. Maybe Bursons or repco
    We'll get you going.
    Like I told you, I can get back to you on Monday morning.
    Keep us posted if your got everything ready I could possibly get out to you tomorrow morning, as it's not much to do it shouldn't take too long.
  10. #168
    What I think I have is some stuff I can put in the old thread
    let it harden and then just re tap it, but I think a heli coil
    would be a better fix, No rush now lol
    Is it called chemi weld or similar
  11. #169
    Yeah, pulled the tread out before it was tight. The top bolt was done first with no issues, tried to do the same and it went pear shaped.
    Kinda relieved that it was no ones fault, just one of those things.
  12. The Following User Says Thank You to jay see For This Useful Post:
  13. #170
    Can anyone confirm if that chemi weld putty would be up to the task
