Page 122 of 220 FirstFirst ... 120121122123124 ... LastLast
Results 1,211 to 1,220 of 2192
Thread: AB's new GQ is finally here
  1. #1211
    Fitted a 90 bend to the oil feed on the new turbo as the original line was too close to manifold, much better now!
    Booked into Exhaust Fix to make up a dump pipe and I'm officially back on the road as of tomorrow.
    I'll book it in to get a dyno next week on the 10mm pump and see how this performs.
  2. The Following 3 Users Say Thank You to AB For This Useful Post:
    Clunk (14th April 2016), MudRunnerTD (14th April 2016), Winnie (14th April 2016)
  3. #1212
    Dump pipe on...so much quieter now...boooo!!!
  4. The Following User Says Thank You to AB For This Useful Post:
    MudRunnerTD (28th April 2016)
  5. #1213
    I had a stupid autometer probe put into the exhaust after the dump pipe using the clamp and ceramic washer when I first got the vehicle.
    I want to do things properly now tapping into the dump pipe of course so do I have to start fresh with a whole new set up or can I get a different probe to suit my existing set up, wiring, autometer gauge, etc?
  6. #1214
    My battery also finally died during this build, finally not holding charge at all!!
    Had to roll start to get it to exhaust shop today..... .07 of a volt after charging for a week!
    Being a long time coming unfortunately so just purchased a new Bond battery from Patrolapart.
    It's never ending...lol
  7. The Following User Says Thank You to AB For This Useful Post:
    Stropp (15th April 2016)
  8. #1215
    Yes you can buy another probe. Is there anything wrong with the probe you have? They should be able to weld in a bung to suit it and it would be a direct fit.
  9. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    AB (15th April 2016)
  10. #1216
    I need to have a good look at it as its in the back of the car, the exhaust shop just asked me to find this out first and I just got home so no idea at this stage mate.
    Maybe my probe built for ceramic washer and clamp style can't be used in bung thread application?
  11. #1217
    Nah the chances are it is screwed into a bung designed to be strapped on like you had it, you should be able to unscrew that and have the bare probe with thread ready to be install with any option. Mine was like that at least.
  12. #1218
    Yeah cheers mate, I'll have a good look tomorrow.
    He mentioned something about how it wouldn't work for some reason but I'll take a look tomoz.
  13. #1219
    Is the noise like i told you?
  14. #1220
    Spot on!
    I need someone to drive it for me so I can hear it outside driving by though but you were spot on with the quietness of it now but still know it's a td42.
