Page 15 of 44 FirstFirst ... 1314151617 ... LastLast
Results 141 to 150 of 434
Thread: Threedogs motor thread
  1. #141
    Expect a report on the temps in the next few days john, with good results...
  2. The Following User Says Thank You to jay see For This Useful Post:
    Rossco (14th April 2016)
  3. #142
    Heres something funny went for a spin temps started climbing
    so I returned home only to see some green stuff pouring out.
    Lift the bonnet and what do I find,,,,,,,,,,,,,,,,,,,,,,,,,,,,, lol
    the hose to the overflow tank was not on so I put it back on and tightened it
    topped it up, will go for another drive late lol lol
    Gawd i hope it was only that.
  4. #143
    Nah all gone to shite, needed to go to the Docs 22k kept eye on temps they were 88 so not too concerned.
    On the way home that when things went pair shaped stopped at a set of lights and had steam pouring out the
    scoop temps were still fine , but obvious there was a problem.
    It seemed to be coming from where the thermostat housing fits. It boiled just as I got home.
    at my wits end over this,,,,Its not coming out where I drilled and tapped the sender hole.
    Ive got a heap of appointments coming up as well
    Question why doesn't motor go into limp or something when engine over heats
  5. #144
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Did you say the engine temps were fine though?
    >>>tappin from tassie
    Hello from Under Down Under!
  6. #145
    Yep temps were a tad high but stable and recovering I think the thermostat housing
    is loose or no in correctly, Prik of a spot but that my thoughts on it
    Either way coolant is pouring out
  7. #146
    177 Post(s)
    Only protection is it cuts the air con out I thought...
    But you said Temps were fine so it didn't over heat ???
    Somethings going on...
    yeah I think its the thermostat housing unfortunately
    I've never had steam and coolant from that area before
    This may be the reason my temps were a tad high?
    what ever reason it all has to come out again ,
    Anyone free??
  9. #148
    Ah bugger 3d, especially as those things are such a prick to get too. If it lost coolant would explain temps going up. Did you guys put some goo on when it went back together?
  10. #149
    No it was an O ring job no one suggested to use any goo ?
    @ Hodge it took from my place to the western ring road
    on Ballarat rd to get to 83 degrees about 8-9 kays its always
    taken a long time to get to temp
  11. #150
    SUCH IS LIFE Maxhead's Avatar
    ACT
    I thought Mark did
    ________________________
    ______ 2017 D-Max _______
  12. The Following 2 Users Say Thank You to Maxhead For This Useful Post:
    BigRAWesty (14th April 2016), Winnie (14th April 2016)
