Results 21 to 30 of 44
Thread: Stuck open thermostat.
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    A thermostat is a fairly lazy device. I am not sure how long it would take from fully open when you are driving hard to fully closed when stopped at the lights. Its possible I would think that the temp is falling off until the thermostat catches up and regulates the temp of the water as it is supposed to do.
  2. #22
    Aug 2011
    River Heads Q
    4 Post(s)
    Hmm interesting.. did you test thermostat before installing?
    Brand new one
  3. #23
    84 Post(s)
    Yep I have been stuck on the side of a busy highway because the brand new thermostat I had put in failed to open, I test any thermostat I am going to install and I advise anyone to check them by putting them in a pot of boiling water and seeing they work.
  4. The Following 4 Users Say Thank You to mudnut For This Useful Post:
    BigRAWesty (13th April 2016), dom14 (19th April 2016), threedogs (21st April 2016), Wizard52 (22nd April 2016)
  5. #24
    483 Post(s)
    Those symptoms are either a failed thermo or no thermo at all
  6. #25
    483 Post(s)
    Apologies ET for ...... Forum Runner makes us add at least 10 characters :-(
  7. The Following User Says Thank You to MB For This Useful Post:
    the evil twin (14th April 2016)
  8. #26
    483 Post(s)
    <img src="http://www.nissanpatrol.com.au/forums/attachment.php?attachmentid=66172"/> this is a thermostat from a td42. seized open. couldn't get it warm normal driving had to thrash it up a steep hill to warm it a bit. then it would cool off pretty quickly.
    Nihao Garett,
    Cooling systems on any car are strange and confusing at best, well stock designed by Nissan we have :-) !
    My own personal experience is that in an emergency we can pull out any cars jammed TS and thereafter experience exactly what you're describing.
    Cheers MB
  9. The Following User Says Thank You to MB For This Useful Post:
  10. #27
    So I'm really unsure now..
    Had car up to 87oC tonight and now had it idling for about 10 mins and it's only dropped to 84oC...
    It's currently 11.5oC outside..
    Maybe it's in its way out..
    483 Post(s)
    G'day Westy,
    Such a cheap and easy part to changeover/test, honestly worth a try first old mate!
    Yanks I've worked with change em seasonally to suit their radical climate +/- 110/40 :-)
  12. The Following User Says Thank You to MB For This Useful Post:
    BigRAWesty (21st April 2016)
  13. #29
    G'day Westy,
    Yea I've had a look at the zd30 thermostat location. ...
    It's not pretty lol
    177 Post(s)
    Just ask threedogs he just went through that drama lol.
  15. The Following User Says Thank You to Hodge For This Useful Post:
