BigRAWesty (11th April 2016), mudski (11th April 2016)
Im not too bad in small spots, you may be surprised what John and I can acheive
Plenty of bandaids he he he
Ow yea.. I just remebered all this chat of a shoit location on the 3ltr
Yep, on my own cars.
No not really, sames things just in a different place. Will work our way through it. I've had a heap of different of cars over the years.
Always up for a challenge....
Well well see about that.
Hopefully not.
this is a thermostat from a td42. seized open.
couldn't get it warm normal driving had to thrash it up a steep hill to warm it a bit.
then it would cool off pretty quickly.
BigRAWesty (12th April 2016)
Just installed VDO temp gauge in ute and noticed same issue. Temps vary from about 75 to 85 degrees depending on load when on the move but yesterday in Brisvagas traffic noticed temp just once drop to about 50 when stopped at lights. New thermostat installed at same time as new Dessert Cooler radiator and gauge.
Hmm interesting.. did you test thermostat before installing?
But if your working your engines hard and temps rise a bit while at it, when you back of go slow stop and idle
then the temps are going to drop any way ?
