Page 1 of 5 123 ... LastLast
Results 1 to 10 of 44
Thread: Stuck open thermostat.
    Ok so today while driving around I've noticed the normal driving temp ranges from 83 threw to mid 90's.
    But when pulled up and at idle for 5-10 mins coolent temp drops right off to like 60 ish..
    Now my understanding is the thermostat should close keeping engine temps up around 80 odd and then open when around 88??
    So with my temps dropping so low is it unreasonable to suspect a stuck open thermostat?
  2. The Following User Says Thank You to BigRAWesty For This Useful Post:
    MB (22nd April 2016)
    Patrol Freak trekster's Avatar
    Nov 2012
    Coffs Harbour, NSW
    How are you measuring the temperature? Aftermarket gauge?
    1998 GU RD28T: RIP
    1996 GQ RD28T: RIP 11 days later
    Hello 2012 GU CRDZD30
    Nissan winchbar + Warn, Dual Battery/Redarc, UHF and Titan rear drawers
  4. The Following User Says Thank You to trekster For This Useful Post:
    482 Post(s)
    Sounds absolutely plausible to me mate!
    What ambient temperature was today in your neck of the woods firstly?
    BigRAWesty (11th April 2016)
  7. #4
    482 Post(s)
    Pull the stat out, chuck it in a pot on the stove with a thermometer and watch what she does:-) ! Battery 1% over&out mate!
  9. #5
    Those symptoms are either a failed thermo or no thermo at all
  10. The Following User Says Thank You to the evil twin For This Useful Post:
  11. #6
    Or feel the hose that feeds the thermostat..... it'll be firm when the thermostat is closed and fairly soft when open.......... or you can keep the radiator cap off and watch the flow of coolant back into the radiator. ...... well that's what I used to do with my old TB42
  12. The Following User Says Thank You to Clunk For This Useful Post:
  13. #7
    This is what I done. My stat was stuck open my about 2-3mm.
  14. #8
    Sorry. Should have written..
    Temps taken off the scan gauge..
    And we've had quite mild temperature here, around the mid teens to low 20's.. I'll get wife to observe more as she's in it more than me..
    So your an old hand at this, good to hear
  16. The Following User Says Thank You to threedogs For This Useful Post:
  17. #10
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    4.5 is different to a 3L
  18. The Following User Says Thank You to Sir Roofy For This Useful Post:
