Page 2 of 44 FirstFirst 1234 ... LastLast
Results 11 to 20 of 434
Thread: Threedogs motor thread
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    It sounds like there might be nothing wrong with your engine mate and just the cooling system is not up to scratch.
    So no ls1 then :-(
    >>>tappin from tassie
    Hello from Under Down Under!
  2. #12
    I'm with Winnie on this one mate and good to do one thing at a time, start with the easiest and cheapest.
    Yell out if you need a hand, just not this weekend working.
    Yendor, you sure that fan kicks in at 100 degrees, if so that's a good way to check the accuracy of the temp gauge, both original and aftermarket.
  3. The Following User Says Thank You to jay see For This Useful Post:
    threedogs (7th April 2016)
  4. #13
    Im a big fan of doing one thing at a time so Ill know what exactly is the problem
    Bugger that. I would give the entire cooling system an overhaul. If your problem is fixed at the end of it all, who cares what the problem was. It could be a lot of smaller things too.
  5. The Following 4 Users Say Thank You to Winnie For This Useful Post:
    macca (30th April 2016), mudski (7th April 2016), rusty_nail (17th April 2016), threedogs (7th April 2016)
  6. #14
    177 Post(s)
    I'm with Winnie on this . Especially with the cooling system most things would need coolant dropped... just bite the bullet if you can and give the whole thing a full flush and change bits while the system is empty.
    Especially if that leak solution you poured in blocked up the system even more.
  7. The Following User Says Thank You to Hodge For This Useful Post:
  8. #15
    Nah this aint gunna work need to pull some favours where possible just stood up for 5 mins and collapsed.
    Those that have been here have seen it ,bloody painful I can tell you. ok time to med up I think
  9. The Following User Says Thank You to threedogs For This Useful Post:
    BigRAWesty (10th April 2016)
  10. #16
    177 Post(s)
    Another question have you taken this to any shops to get the looked at ?
  11. The Following User Says Thank You to Hodge For This Useful Post:
    jay see (7th April 2016)
  12. #17
    NO is a quick answer as I didnt think it was a big deal at the time
  13. #18
    Maybe just get it booked in somewhere to find out what is the cause.
    Then you can decide on what you can do.
  14. The Following 2 Users Say Thank You to jay see For This Useful Post:
    Cuppa (7th April 2016), threedogs (7th April 2016)
  15. #19
    Ballarat, Vic
    178 Post(s)
    Quote Originally Posted by relyimah View Post
    TD, I had a compression test done and it passed. And a sniff test or whatever it is. Also passed. Turned out head was cracked over 4 cylinders.
    Had similar issues (pressure building overnight etc). May not be what you want to hear, but does sound familiar
    What does "holding residual pressure for a while after shut down" mean? Coolant not being sucked back into radiator as motor cools down?
    Hate to say it but I also think it's sounding like either a cracked head or a cylinder head gasket blowing between cylinders. Given that it runs ok for 20kms or so before playing up I'd guess that the cracked cylinder head is more likely.
  16. #20
    See thats a new [reco] motor right there,,, as the labour to fix the head gasket is more than a motor
    I dont sit on a big pile of money here , I'm on a disability support pension,so options are limited so it may
    end up being a boat anchor. Ill try and get most of the cooling system out over the weekend
