Page 75 of 101 FirstFirst ... 7374757677 ... LastLast
Results 741 to 750 of 1003
Thread: Hodge's new 4.2
  1. #741
    Clutch- will most likely me a pressure plate fault. Probably lost its tension with the way it was used prior to you putchasing it. You may find the clutch plate wont look to bad.
    Coil spacers/insulators- you can get these for both top and bottom. The bottom ones are only thin as the coil is retained differently to the top. You dont want anymore than maybe 10mm on the bottom of the coil. Placing one at the bottom is more for noise reduction. Factory they only come with insulators on the top of the coil.
    Gearbox- that oil looks like it hasnt been changed in quite some time. It will unlikely effect the rollover noise.
  2. The Following 4 Users Say Thank You to nissannewby For This Useful Post:
    Bloodyaussie (2nd April 2016), Hodge (2nd April 2016), MudRunnerTD (2nd April 2016), mudski (2nd April 2016)
  3. #742
    476 Post(s)
    Yeah i think i might have to get some thin spacers for the bottom. Im sure half my noise issues is from the springs.
  4. #743
    For what it's worth they shouldnt make noise.....
    If the top rubbers are fubar then you will get noise but its a noise that is fairly obvious to to be the springs.
  5. The Following User Says Thank You to nissannewby For This Useful Post:
  6. #744
    176 Post(s)
    Getting there, OOI after you put the yellow polyurethane washers on the bottom of the coils
    what did you use on the top just the OE rubber ones??
    Yeah John, the top hat only has the factory rubber thingamajig.
    176 Post(s)
    Thanks Mat. The oil, like a lot of things on this car, haven't been touched since it left Japan.
    Definitely a bit smoother shifts, but the rollover noise remains like you said.
    Clutch, I guess gearbox has to come off anyway so new one will go in while they're at it.
    The bottom spacer is more of a dampener. I got it as it gave me 10mm or so bit more lift up front. I didn't like the way the car was road sniffing due to heavier springs in the rear. Now it sits very nice.
    Replacement rubber spacers are off tap expensive from Nissan. Your 10mm spacer would have been heaps cheaper. I cut my own on the GQ just for noise. Cut out of 6mm reinforced rubber from Clark rubber.
  9. The Following User Says Thank You to MudRunnerTD For This Useful Post:
  10. #747
    176 Post(s)
    It's from ARB and are OME branded. I think they are around $20-30 for the set... Have no idea whether that's dear or not.
    176 Post(s)
    More goodies !!!
    Tapatalked from S6
    here they are
  12. The Following 3 Users Say Thank You to Hodge For This Useful Post:
    BigRAWesty (5th April 2016), Bloodyaussie (2nd April 2016), MudRunnerTD (3rd April 2016)
  13. #749
    Thomastown, Melbourne
    6 Post(s)
    here they are
    Good stuff... i need some as i get squeaking from my front springs and if mudski or yourself are near arb can you grab me a set as i am now working so bloody much i will never get a chance at this rate to get some myself.
  14. #750
    Around $6us plus postage....
