Results 21 to 30 of 45
Thread: Show us handy tools in yor box
    Patrol Guru Kimbo63's Avatar
    Dec 2015
    Perth WA
    5 Post(s)
    Personally I think Snapon are grossly overpriced, there are plenty of brand names out there with life time gaurantees
    My mate broke a small brako bar [sidchrome] 30yrs old or so took it to Repco no questions asked swapped it over.
    I have had no problems with my kingkrome gear they did give me an up dated 1/4 drive rachett, even though the old was still good.
    Don't forget TD if you break your only breaker bar out in the middle of nowhere where are you going to get it swapped? You just can't break a Snapon bar with your bare hands
  2. #22
    Patrol Freak lhurley's Avatar
    Oct 2011
    Brisbane. Manly West.
    If you use them quite often good tools are definitely worth it. I have a sidchrome ratchet and a snap on ratchet, sidchrome gets jammed, doesn't have as many teeth on the ratchet and is wobbly. It's nearly new too. Snap on one is hands down significantly better plus has more teeth on the ratchet so makes it much nicer to use in tight areas.
    I have a few other brands of tools and you definitely get what you pay for. Will also round less fasteners with quality tools.
    1999 GU DUAL FUEL 4.5 - 2" OME - 33's KM2s - SNORKEL - CUSTOM DINTS.... Goes by the name Candy (the car not me )
  3. The Following User Says Thank You to lhurley For This Useful Post:
    Kimbo63 (30th March 2016)
  4. #23
    Dec 2015
    WA
    5 Post(s)
    You can also get ratchet overhaul kits for the Snap-On, the same ones are used in their torque wrenches.
    They are the only ones I know of with 1/8" open end spanner, also bought 5/32" & 3/16" all around $30 each.
    Their ratchet screwdrivers are the only ones to get, the #2 phillips bit outlasts any other.
    Graham
  5. The Following User Says Thank You to GeeYou8 For This Useful Post:
    Kimbo63 (2nd April 2016)
  6. #24
    Oct 2010
    Old Bar, NSW
    Bought a set of Sidchrome sockets when doing my apprenticeship in 1974, busted a few bits over the years, ratchet handle and some sockets.
    They have been replaced without question. Recently busted a socket, the bloke behind the counter had a good look to see if it had been used in a rattle gun.
    No sign so replaced on the spot.
    Not bad after 42 years. Didn't have a receipt either!
    Buy once Buy right! "Canna hand a man a granda spanna" or something like that.
    https://www.youtube.com/watch?v=AY4upxZ_zOs
    Old Reliable, sitting under a bench in the cave, been there for years.
    Cost $18.00 in '74, subsidised as factory was going metric.
    And another I bought for work, everthing in one case. It is really handy, so good it goes out back with me on the desert trips.
    Cost $124.00 in 2104! (Supercheap Autos special)
    Heres another interesting Sidchrome ratchet. Model 13914.
    Works as a conventional ratchet, also the handle twists either way and tightens or undoes what ever the head is set at. So in a tight spot just twist the handle not swing the arm IYKWIM.
    $5.00 in a dead stock bin at Bunnings. Too interesting to resist!
    Also have some Snap-on stuff from our racing days, small profile tools for tight spots and tough as. But bends the card when buying it though.
    Macca
  7. The Following 2 Users Say Thank You to macca For This Useful Post:
    Kimbo63 (1st April 2016), threedogs (31st March 2016)
  8. #25
    Advanced AGman's Avatar
    Mar 2016
    Probably the three handiest tools I have in my arsenal at the moment.
    I have some Snap-On flare-nut wrenches and some screw drivers Ive had for ever...it's nice stuff.
  9. The Following User Says Thank You to AGman For This Useful Post:
  10. #26
    Quote Originally Posted by Kimbo63 View Post
    Put it the hands of a farmer who will more than likely put a piece of 3ft pipe over it to get a bit of extra leverage
    Ill gaurantee you it will break. but thats not under normal use.
    Plenty of better tool than Snapon out there Williams are a fantasic tool feel great in the hand.
    Maybe Im a bit anti America.but I still think they are well over priced compared to other tools
    with the same warranty etc.
  11. The Following User Says Thank You to threedogs For This Useful Post:
  12. #27
    Can NEVER have too many tools EH
  13. #28
    Have you or do you own any snap on tools?
  14. #29
    I've used them a few times, just thought it was doing the same job as say a Kingchrome smooth edition.
    Sorry Matt just cant justify the high price, It may be different for you as your stuffed without tools, as
    tools are your life. Im talking from say Hodge or Mudski and Co where we use them fairly often but not all
    the time like you and others if that makes any sense
    PS been locked in the truck a few times lol
    Have used them but dont own any
  15. #30
    Oct 2010
    Old Bar, NSW
    Had a look for Williams as I had not heard of them, found this...
    http://toolguyd.com/snap-on-industri...s-bahco-tools/
    Macca
  16. The Following User Says Thank You to macca For This Useful Post:
