Page 74 of 101 FirstFirst ... 7273747576 ... LastLast
Results 731 to 740 of 1003
Thread: Hodge's new 4.2
  1. #731
    @ DOM surely you have heard of ppl wanting to fit say 30mm coil/spring spacers.
    The thin ones are far better than the OE rubber gasket they use.
    When Im feeling a bit better Ill buy a slab of coopers and come up ha ha
  2. #732
    176 Post(s)
    Hey Eric just catching up on your thread. Are you doing a big 100,000km service? Is your clutch done at 100,000kms!!!! Wow! My GUIV has 260,000kms on it now, I bought it at 94,000. Still has the original Clutch. Only in the last couple of months have I thought it might be coming to an end. 100k seems crazy!! Be interested to see what it looks like when it comes out??
    How much are they charging you to do the clutch? What was the TT Clutch worth?
    Hi Darren sorry for delayed reply.
    Yes I am slowly ticking off items good for 100k service. Some things I can't/don't know how to do my self, like brake fluid, valve clearances etc... Which will be done at JPC.
    As for my clutch... Well... I only "suspect" it as being stuffed.
    Possible symptom 1 : Since I bought the car, a lot of the times when I take my foot of the pedal I hear a "clunk" which varies in harshness. Initially I thought this was somewhere further down the driveline, but this also happens when tranny is in neutral.
    Possible symptom 2 : Going up a steep section up in the high country recently, in 1st low, all of a sudden it's as if I hit something and I wasnt going forward any more, car began rolling backward. I think, the clutch slipped then...
    Possible symptom 3: Recently Mudski jumped in my car and he said my clutch is engages at the very last play of the pedal. I would have been none the wiser...
    All other times gears change fine and it never slipped or anything like that apart from the clunk (symptom 1).
    When I spoke to Mark at JPC he didn't know what to think of it, but found it very surprising clutch is gone before 100k... Unfortunately to inspect properly, gearbox out etc... I think it's around $800 mark for labour to swap it out.
    So I impulse bought the clutch off Mark which he no longer needed and was brand new from 4Terrain. Just under $500 including the awesome timber box.
    The other thing is my car towed a caravan around Aus, I don't know how big. But maybe that has something to do with early clutch retirement ?
    For all I know this clutch could be perfect but something else at play causing my symptoms? Don't know.
  3. The Following User Says Thank You to Hodge For This Useful Post:
    MudRunnerTD (2nd April 2016)
  4. #733
    That was a good idea letting Mark have a drive.
    Years ago when we were all riding bikes we used to swap
    every 3 months or so to pick up any faults.
    Being the owner you don't really feel things deteriorate slowly
    as you adjust and just get used to it, hope that made sense, lol
  5. #734
    476 Post(s)
    As TD said mate it just to help raise the front a little bit ... They come in 10mm and onwards in sizes...
    Im confused why they are on the bottom of the spring. All the ones ive seen are on top....
  6. #735
    176 Post(s)
    I think there is both... unsure what difference it makes.
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    Yeah that's what had me confused too Mark. I thought spacers went on the top
    Lucus30's 1999 GU ST TB45E
  8. #737
    Possibly used to replace to factory rubber..
    Thats what my moneys on, less noise to I suspect
  10. #739
    176 Post(s)
    Just replaced the gearbox oil. Oil was still oil but a bit murky. Nothing but micro-shavings and sludge on the magnet, which is good.
    Hardest part was getting the car level enough for accurate re-fill.
    Another item ticked off the list... Also hope this lessens the infamous gear chatter/rollover rumble this thing has.
    Getting there, OOI after you put the yellow polyurethane washers on the bottom of the coils
    what did you use on the top just the OE rubber ones??
