Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Removing sealant from rain gutters?
    Can you put a brass wire wheel on a drill and remove the rust that way.
    As you say I still think Drip Check is the go
  2. #12
    Advanced UVB76's Avatar
    Dec 2014
    Newcastle
    If there's nothing but surface rust, I reckon a wire wheel is the right idea. I was thinking more along the lines of whether or not it'd be worth applying some kind of rust converter/sealant just in case the Drip-Chek fails in future years.
    Big Red '99 RD28
  3. #13
    wire brush, then some kill rust paint then the drip check
  4. #14
    Jun 2013
    Keilor East Vic
    Hey UVB76
    If the sealant has cracked then there could be a chance that moisture has got in and under it. If this is the case running more sealant over the top is
    going to leave you with a big rust problem later on. Roof Racks are the worst for this. If you go down to your local Bunnings you can get abrasive scouring
    disks similar looking to what you wash dishes with. There are different grades of course disks. Get the arbour that goes with them.
    When you get home put the arbour in your drill and away you go, this will get out the hard cracked sealant, and keep an eye open for any rust.
