Page 72 of 101 FirstFirst ... 7071727374 ... LastLast
Results 711 to 720 of 1003
Thread: Hodge's new 4.2
  1. #711
    Patrol Guru Rocket55's Avatar
    Sydney
    I got a Supercheap ( I think) creeper about 10-12 ago. Has a steel frame with padded foam inserts, works a treat, strong as and cheap as chips.
    Cheers Rod
    My Build 2005 TD42TI
  2. The Following User Says Thank You to Rocket55 For This Useful Post:
    Hodge (28th March 2016)
  3. #712
    177 Post(s)
    This was a supercheap cheap one. I guess I'll have to go and grab a new one. .. Mind you I did put some unordinary forces on it no wonder it snapped .
    Patrol Freak lhurley's Avatar
    Oct 2011
    Brisbane. Manly West.
    Those plastic supercheap ones are the devil. I have a metal frame one from there and its pretty ordinary. Cant say ill buy another supercrap one
    1999 GU DUAL FUEL 4.5 - 2" OME - 33's KM2s - SNORKEL - CUSTOM DINTS.... Goes by the name Candy (the car not me )
  5. The Following User Says Thank You to lhurley For This Useful Post:
  6. #714
    177 Post(s)
    Gonna rotate the tyres as it's time. Is this the general rotation to follow on a 4x4 ...
    Patrol Freak Bacho86's Avatar
    Mar 2011
    14 Post(s)
    When rotating my tyres using only 4 (spare is different brand and only good for spare) I swap rears to front and then front to rears , swapping sides (passenger to drivers) to promote even wear -- hope that makes sense!
  8. The Following User Says Thank You to Bacho86 For This Useful Post:
  9. #716
    177 Post(s)
    Makes sense mate. I got 5 identrical rims and tires. And every manual I check shows something different.
    I just move mine around the car in a clockwise pattern. Do this every 5000km. I netted nearly 100k out of the last set doing this.
  11. The Following User Says Thank You to nissannewby For This Useful Post:
  12. #718
    177 Post(s)
    Not a bad idea might just do that. SO it ends up...
    LR to LF
    LF to RF
    RF to RR
    RR to Spare
    SPare to LR .
    My current rears are a tad more worn than fronts. I guess due to strong nissan lsd.
    177 Post(s)
    All rotated, I'll stick to Matt's rotation every 4-5k from now. Front hubs have severe corrosion, once again shows the car has been dipped in the ocean plenty... Went out and got the rest of the oils but will run out of time today. Next weekend, which will also be time to re-flush the rear diff.
    All rotated, I'll stick to Mat's rotation every 4-5k from now. Front hubs have severe corrosion, once again shows the car has been dipped in the ocean plenty... Went out and got the rest of the oils but will run out of time today. Next weekend, which will also be time to re-flush the rear diff.
    Fixed it.
    Dont forget things like power steering and brake fluid .
  15. The Following User Says Thank You to nissannewby For This Useful Post:
