Results 1 to 10 of 19
Thread: What would you do?
    Mar 2016
    Canberra ACT
    What would you do?
    Being new to the scene I've been trying to do a fair bit of reading as to where to start on my 2010 3.0L CRTD. Funds at the moment are fairly limited as the Minister of War & Finance has put the reins on.
    So far I'm looking at putting a EGR blocking plate in off ebay, wondering how much to spend on a catch can & which one to go with. Another thing is I could potentially pick up a 3 year old DP Chip for close to $600, on the flip side I've read the DEA Exhaust systems are pretty good also at $600 delivered. What would be the better option performance wise?
    Any other suggestions or redirection of priorities?
  2. The Following User Says Thank You to Firetrol For This Useful Post:
    BigRAWesty (21st March 2016)
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    try and source all your bits from reputable eBay sellers - nothing worse than paying twice for something (first one wrong / not what you need etc.............)
    but to do this
    research
    research
    research
    catch can - I know of a bloke who used a 500ml plastic coke bottle as one (replaced everytime he does an oil change) - if you can make it - better than buying it
    is your exhaust stuffed.........?
    if not - why replace it yet
    dont worry about the "chip" just yet, you need to do the NADS first and foremost (EGT gauge, Dawes Valve, proper Dyno Tune, etc.......)
    some say you dont need to with the CRD - but prevention and knowledge is better than something going bang, then asking why
    better performance options......... mmmmmmmmm
    make sure your tyres are at around 38-42psi
    dont carry all your back shed in the car when travelling
    mud terrain tyres use more fuel to push and wear out quicker than All terrains do
    all depends on what you want it for, and how you drive it
    daily driver & weekend play toy
    serious off road extravagance
    long distance touring
    all these things need to be sorted and taken into consideration
    hope some of this helps you
  4. The Following User Says Thank You to Bigcol For This Useful Post:
    dom14 (25th March 2016)
    Do what Evil Twin always suggests before doing anything...... get a Scangauge, or ECUtalk, or what ever its called
  6. The Following 2 Users Say Thank You to Clunk For This Useful Post:
    BigRAWesty (21st March 2016), dom14 (25th March 2016)
  7. #4
    What he said ^^^^^
    ROFL....
  8. The Following 2 Users Say Thank You to the evil twin For This Useful Post:
    Avo (20th March 2016), BigRAWesty (21st March 2016)
  9. #5
    Mar 2016
    Canberra ACT
    Thanks for your replies & info fellas. Bigcol, I use it as a daily driver & weekend warrior trips. The standard exhaust is fine, I was just looking for better performance from a 3".
    I will only be putting A/T's on the standard 17x8 alloys, Yokahama GO12 in 285/70/17 is what I'm looking at.
    Although the CRD's are supposed to be "safer" from going bang, as you said I'm still keen on prevention rather than cure.
    Once again all advice is good, cheers.
  10. #6
    Check the condition of the OE intercooler with the Patrol
    being 6 years old chances are the IC is oily and leaking.
    Buy a Tig welded one to replace it'
    You'll find fitting the Beaudesert 2.75" exhaust a better option
    for the CRD..
    Dont bother about blocking the EGR or any other mods till you
    have a way to monitor what changes occur first.
  11. #7
    Mar 2016
    Canberra ACT
    for the CRD..
    So remove the intercooler & check for oil residue, how would i know if it's leaking threedogs?
  12. #8
    476 Post(s)
    Quote Originally Posted by Firetrol View Post
    If you have oil deposits on the outside of the cooler. This is a good sign that its stuffed.
    As to what bigcol said about the NADs.
    The CRD's dont need this at all. Period. But using these will alter the power delivery so much better the car will be a different animal to drive.
  13. #9
    Personally start with your gauges..
    Scan gauge does all but egt and oil pressure.. Imo 2 big ones..
    I have blocked my egr completely and have had no issues with it throwing codes but some do..
    The scangauge will let you clear those codes if it happens. .
    Catch can.. well there are so many varieties it's really personal opinion.. but a good thing.. not under performance in my list though but maintenance of the engine..
    Once gauges are done the with the crd it's uo to you..
    You can do the whole dawes and needle valve setup but they do hold 16 psi well.. if you want to push it more then the valves are needed.. many say 18-20 psi is the sweet spot for these engines..
    The 3" exhaust may throw it into limp mode due to spool up being too quick.. if this happens then the dawes and needle valves are the fix..
    Once the basics are done then it's how far you wanna go..
    Upgrade the intercooler.. upgrade intake.
    Upgrade turbo..
    How deep are ya pockets lol..
    A bloke in QLD has dropped $27g into his engine..
    The only stock thing is the case lol.. But it is insane.. spins 37" tyres with ease..
  14. The Following 2 Users Say Thank You to BigRAWesty For This Useful Post:
    4bye4 (21st March 2016), Bigcol (21st March 2016)
  15. #10
    Mar 2016
    Canberra ACT
    Thanks for your input on the NADs mudski. Having only driven the Patrol for a month I'm seeing a need/want for smoother & better power delivery.
