Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Air intake TB45E
    Patrol Guru Chubba's Avatar
    Oct 2013
    Adelaide
    5 Post(s)
    Air intake TB45E
    Today I was busy wrapping my extractors with heat shield wrap.
    To improve access I took part of the air intake off. I was wondering if anyone could explain what purpose this chamber on the side serves. Dose it swirl the air to remove moisture. But there's no drain.
    I don't know, just curious if someone could explain.
    98' Ti, 4.5L, 2" lift, factory rear diff lock with front E-locker, 63% reduction gears
    "GO YOU CROWS"
    It's like a storage chamber of fresh air so when you boot it the engine has a small supply air already filtered..
    Also aids in intake noise..
    So really..
    A waste of space lol
  3. The Following 2 Users Say Thank You to BigRAWesty For This Useful Post:
    Chubba (13th March 2016), jay see (13th March 2016)
    I've still got mine on, so if I was to remove it would it make any difference good or bad?
    North brissy
    Dont remove it. They are designed like that for a reason and for the most part work very well.
  6. The Following User Says Thank You to nissannewby For This Useful Post:
    Ok it stays then. Lucky tho, every time I open the bonnet and see it I'm tempted to take it off. One job not need doing.
  8. The Following User Says Thank You to jay see For This Useful Post:
    BigRAWesty (13th March 2016)
  9. #6
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    Where is it? Never seen it on mine
    Lucus30's 1999 GU ST TB45E
  10. #7
    Oct 2013
    Adelaide
    5 Post(s)
    Quote Originally Posted by lucus30 View Post
    Very top of motor hanging off the air pipe from the air filter to the inlet manifold. Sits directly above 5 and 6 exhaust ports.
    "GO YOU CROWS"
  11. #8
    Sep 2013
    16 Post(s)
    Oh ok mine obviously doesn't have one. I'd say due to the gas conversion
  12. #9
    Oct 2013
    Adelaide
    5 Post(s)
    I've got LPG and so does Jay see
    "GO YOU CROWS"
  13. #10
    Could be depending on the system used and how it was installed..
