Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: OME 2" lift castor correction kit
    Expert rusty00's Avatar
    Jun 2015
    South Eastern VIC
    Cool have the equipment so all good.
    Looks easy enough.
    2012 GU8
  2. #12
    Patrol Freak garett's Avatar
    Jan 2015
    north
    21 Post(s)
    clean the threads with a wire brush ... that was a 6 hr mistake ....
  3. The Following User Says Thank You to garett For This Useful Post:
    rusty00 (9th March 2016)
  4. #13
    Jun 2015
    South Eastern VIC
    Lift kit installed.
    It drives really well without the castor kit, but will install over the weekend.
    I thought the lift would have allowed the front mud flaps to be put back on, not the case.
    There is only 20mm between the wheel and inner flare, might have to cut a section of flare off to stop it catching when at flex or tyre compressed at the front.
    2012 GU8
  5. #14
    Quote Originally Posted by rusty00 View Post
    Lift kit installed.
    radius arm spacers will fix that, get some for when you do your castor correction
  6. The Following User Says Thank You to Clunk For This Useful Post:
  7. #15
    My kit came with the castor correction, some say its not really needed, but if you can fit them it all helps keeping everything in line.
  8. The Following User Says Thank You to jay see For This Useful Post:
    rusty00 (10th March 2016)
  9. #16
    Lift kit installed.
    If you wanna sell your front mud flaps let me know. Im looking for some.
    And i have a set of new radius arm spacers too here if you want....
  10. #17
    Jun 2015
    South Eastern VIC
    Will keep the flaps, want to put them back on.
    Can you send a pic of the spacers, not sure what they are.
    Pm me a price please.
    2012 GU8
  11. #18
    See link for what they are.
    http://www.ebay.com.au/itm/Suits-Nis...kAAOSw5dNWocri
    They basically push the radius arms forward so the tyre doesn't hit the guard. I bought them and never bothered to fit them.
    $30 posted if you want them.
  12. #19
    Jun 2015
    South Eastern VIC
    Just need to check the distance, but will grab them off you. PM me your bank details.
    The ebay add reads
    It is recommended that you check the clearance from your diff to your panhard rod before and after fitting these Spacers. The Panhard Rod and Diff Centre run very close on some GU models depending on other suspension work that has been done on the vehicle. Pushing the diff forward with these spacers can result in the panhard rod making contact with teh diff or the front of the radius arm, affecting the articulation of the panhard rod, which can place additional stress on the panhard welds and brackets, leading to premature failure.
    2012 GU8
  13. #20
    Jun 2015
    South Eastern VIC
    Deposit paid to your account Mark.
    2012 GU8
