Page 115 of 220 FirstFirst ... 113114115116117 ... LastLast
Results 1,141 to 1,150 of 2192
Thread: AB's new GQ is finally here
  1. #1141
    Forgot to mention, used the freeze and release can as well.
  2. The Following User Says Thank You to AB For This Useful Post:
    MudRunnerTD (5th March 2016)
  3. #1142
    334 Post(s)
    Good job bloke
  4. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    AB (5th March 2016)
  5. #1143
    Good job bloke
    I had to drag poor Rossco over with his welder to weld a nut on.
    There was no way it was coming off without it.
    Even then the welds were cracking and Rossco was watching the engine move as I was undoing the stud.
    Crazy seized!!!
  6. #1144
    334 Post(s)
    Yeah but you won
  7. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    AB (5th March 2016)
  8. #1145
    Yeah they were pretty tight. Think we were lucky must of been getting pretty close to that front stud snapping, pretty crazy how much force was going through that little thing, it was twisting the whole motor!!
  9. #1146
    Just waiting on one more part and I can bolt everything up!
    Made up a new support for the fatz airbox to raise it up another 10mm for better clearance of the 4" pipe to turbo and also to allow the aux battery tray to fit because the oem bottom support angle bracket is in the way of the aux tray.
    Been a challenging task but it's all ready to bolt up!
    Pirtek are awesome! Managed to keep most the original oil water lines, just made up new fittings to suit Borgwarner.
  10. The Following User Says Thank You to AB For This Useful Post:
    Rossco (6th March 2016)
  11. #1147
    This is coming along awesome Andy, can't wait for you to take me for a spin to see the difference.
    (I still have not taken the airbox out of my car since I picked it up)
  12. The Following User Says Thank You to Winnie For This Useful Post:
    AB (6th March 2016)
  13. #1148
    This is coming along awesome Andy, can't wait for you to take me for a spin to see the difference. (I still have not taken the airbox out of my car since I picked it up)
    It does fit good mate but needs slight mod for aux tray and you would need to take a fair chunk of strength away from the alternator bracket so I decided on raising it a whisker.
    Rosscos got your flange too mate, special delivery!
  14. The Following User Says Thank You to AB For This Useful Post:
    Winnie (6th March 2016)
  15. #1149
    Raising it sounds good. Please take lots of photos when it goes back in. Lol.
    I'll catch up with Rossco, cheers for that.
  16. #1150
    Finally got time to jump back on the gq.
    Turbo finally bolted up!
    It's a tight fit, slight panel beating to fit the wastegate in.
    Just need some more 4" clamps, m8 studs, T piece and hose for the recirculation valve, oil drain fitting and I think I'm ready to connect everything up...Yay!
  17. The Following 5 Users Say Thank You to AB For This Useful Post:
    Clunk (27th March 2016), growler2058 (27th March 2016), MudRunnerTD (27th March 2016), Rossco (27th March 2016), Winnie (27th March 2016)
